Since recently I'm facing some issues with my car when the engine heats up to its operating temperature. Car is Lancer CB2 1994 (4G15 Carb engine). when I start the car in the morning it starts up without any issue and engine RPM stays at 1000. But after some driving about 10 mins, following could be noted,
1. When I stop and try to start the engine when it is heated, it starts with difficulty and engine revs slowly around 400 - 500. (without AC). But I don't feel any low pulling power when driving.
2. When heated, it starts to emit smoke but this happens intermittently. (at cold start no smoke)
I have replaced all 4 plugs recently but it didn't help. Also engine miss fires a bit in the morning but goes off when engine gets heated. what would be the reason for above?
Thanks.
PS: Today when I start in the morning it started to emit white smoke after being idle for about 5 mins. I reved the engine a bit and then the smoke turned blue.
hrm
Hi Guys,
Thanks.
Edited by hrmLink to comment
18 answers to this question
