sammycajer Posted September 11, 2012 Share Posted September 11, 2012 Hey guys, can u tell me the best rim/tire sizes for eg8 ride??? Quote Link to comment Share on other sites More sharing options...
nexus Posted September 11, 2012 Share Posted September 11, 2012 in 14 rim size with 175/65 tyres Quote Link to comment Share on other sites More sharing options...
Magnum357 Posted September 12, 2012 Share Posted September 12, 2012 On 9/11/2012 at 5:30 PM, sammycajer said: Hey guys, can u tell me the best rim/tire sizes for eg8 ride??? Go to the link below and enter your stock tyre size and the size which you intend having and see if it's ok. There are factors to consider such as how much your speedo will go out. The link will give you all the info. http://www.1010tires.com/TireSizeCalculator.asp Quote Link to comment Share on other sites More sharing options...
Komisiripala Posted September 12, 2012 Share Posted September 12, 2012 Patta link, magnum, thanks!! Quote Link to comment Share on other sites More sharing options...
sammycajer Posted September 23, 2012 Author Share Posted September 23, 2012 On 9/11/2012 at 6:15 PM, nexus said: in 14 rim size with 175/65 tyres Bro.. What about 15'' rims.. will it be OK??? Quote Link to comment Share on other sites More sharing options...
nexus Posted September 23, 2012 Share Posted September 23, 2012 On 9/23/2012 at 5:20 PM, sammycajer said: Bro.. What about 15'' rims.. will it be OK??? yes you can fix 15 rims to eg8 but if you do so you have to fix low profile tyres to prevent tyre contact with wheel arches(fenders) lower the profile of tyers get harder(uncomfortable) the your ride going to be. Quote Link to comment Share on other sites More sharing options...
chan5 Posted September 23, 2012 Share Posted September 23, 2012 On 9/11/2012 at 5:30 PM, sammycajer said: Hey guys, can u tell me the best rim/tire sizes for eg8 ride??? whatever the change you make , try to keep the diameter of the final Tyre similar to original specs, use the above Tyre calculator, just ignore the facts that Tyre shop man says. Quote Link to comment Share on other sites More sharing options...
shanX Posted October 4, 2012 Share Posted October 4, 2012 195/55/15 Quote Link to comment Share on other sites More sharing options...
KI4120 Posted October 5, 2012 Share Posted October 5, 2012 For optimum perormance and look : 185 - 55- R15 : 185 width makes ideal grip (not too much and too litte) and 55 aspect ratio makes a good cusion for our bumpy roads and 15" radius rim will look fantastic ! Quote Link to comment Share on other sites More sharing options...
kmcsb Posted October 8, 2012 Share Posted October 8, 2012 my one still have OEM sizes..175/70/13.. wht is the best size for handling,performance and fuel effiency.. if i'll going for 15" alloys should i need to put low profile tyres..wht abut 14" ????] Quote Link to comment Share on other sites More sharing options...
H.C Posted October 8, 2012 Share Posted October 8, 2012 On 10/8/2012 at 3:15 PM, kmcsb said: my one still have OEM sizes..175/70/13.. wht is the best size for handling,performance and fuel effiency.. if i'll going for 15" alloys should i need to put low profile tyres..wht abut 14" ????] 195/55/15 Quote Link to comment Share on other sites More sharing options...
Komisiripala Posted October 9, 2012 Share Posted October 9, 2012 (edited) After going through that tyre size comparer, I went down to195/55/15. There's a noticeable difference Car sits lower. Accelerates faster. Power steering is less impeded. Not ashamed to admit I was a tyre noob. Learned the hard way. If the manufacturer specified something, do a lot of research before you try to better it Edited October 9, 2012 by Komisiripala Quote Link to comment Share on other sites More sharing options...
Chanaka Gunawardena Posted October 9, 2012 Share Posted October 9, 2012 On 10/8/2012 at 5:38 PM, H.C said: 195/55/15 On 10/9/2012 at 1:17 AM, Komisiripala said: After going through that tyre size comparer, I went down to195/55/15. There's a noticeable difference Car sits lower. Accelerates faster. Power steering is less impeded. Not ashamed to admit I was a tyre noob. Learned the hard way. If the manufacturer specified something, do a lot of research before you try to better it Running on 195/50/15 in my EK3 There is a slight offset on tires and when there is full load the rear tires brushing the wheel arch. I guess It's all about the alloy wheels. All my friends telling me that the wider tires have impact on fuel economy which I didn't noticed yet. Quote Link to comment Share on other sites More sharing options...
H.C Posted October 10, 2012 Share Posted October 10, 2012 (edited) I dont think it affects fuel economy much. but it gives great grip compared to stock 65/75 profile. Last week i traveled to badulla with 3 adults from Horana in 3hrs 45mins (it was the quickest of my all trips to badulla) and still gave me 13.5kmpl. Most important thing for me was no exsessive tyre noises when cornering and had great grip in both wet and dry conditions Edited October 10, 2012 by H.C Quote Link to comment Share on other sites More sharing options...
kmcsb Posted June 18, 2014 Share Posted June 18, 2014 On 10/8/2012 at 5:38 PM, H.C said: 195/55/15 hi H.C plz chk your inbox..i sent you private msg.. Quote Link to comment Share on other sites More sharing options...
Muditha420 Posted June 18, 2014 Share Posted June 18, 2014 Ok tried to find a decent tire size calculator and came across this, i can't find my particular model from the list but i can put the tire size I'm running on and get a whole list of rim sizes n rubber as well. http://tire-size-conversion.com/tire-size-calculator/ Quote Link to comment Share on other sites More sharing options...
derickreaper Posted October 17, 2014 Share Posted October 17, 2014 (edited) My car has 16" alloy with 195/55/16 tyres and I'm planning to downgrade the size to 15“ like the alloys H.C got... [Deleted by moderator] Edited October 17, 2014 by The Don Advertising 1 Quote Link to comment Share on other sites More sharing options...
The Don Posted October 17, 2014 Share Posted October 17, 2014 On 10/17/2014 at 10:36 AM, derickreaper said: My car has 16" alloy with 195/55/16 tyres and I'm planning to downgrade the size to 15“ like the alloys H.C got... Advertising in the forum is not allowed. You can normally trade your old rims in when you buy new ones from a shop. Quote Link to comment Share on other sites More sharing options...
derickreaper Posted October 19, 2014 Share Posted October 19, 2014 I'm sorry, will take my post down, thank you Quote Link to comment Share on other sites More sharing options...
derickreaper Posted October 19, 2014 Share Posted October 19, 2014 On 10/17/2014 at 12:31 PM, The Don said: Advertising in the forum is not allowed. You can normally trade your old rims in when you buy new ones from a shop. I'm sorry for the inconvenience caused.. Will be extra cautious when posting next time... Quote Link to comment Share on other sites More sharing options...
