If you're on Android, you could also try "Goggles" (by Google).
Can Some one please translate these DPF related instructions to english for me...
These were found on ISUZU ELF( 4HL1 ) equiped with DPF.
Translation given below:
When the DPD indication starts to blink, push the DPD button according to procedure given on the right . If it is blinking slowly, it is possible to drive (the vehicle) while blinking, if it turns to rapid blinking promptly do the procedure given on the right.
Procedure (on the right)
1. Stop at a safe place in idle.
2. Put the change lever to neutral and pull the parking brake.
3. Push the DPD switch.
4. When the DPD indication disappear it is possible to drive. (Normally it will be completed in about 15-20 minutes)
Refer to the user manual for details.
Edited by itsmeud
