Zoom-Zoom Posted December 25, 2012 Posted December 25, 2012 I recently replaced the petrol filter in my Mazda Familia BJ5W and since then it is dragging too much while starting the car and not a smooth start as usual. As soon as I turn off the engine and start again there is no problem.Appreciate if anyone could help me on this. Quote
Rumesh88 Posted December 26, 2012 Posted December 26, 2012 Is it only the starting issue that prompted you to change the filter? It is unlikely to be the cause, because if you had a blockage in the filter it could have been more obvious while trying to accelerate with load. Your fuel supply seems to run dry when you keep the car idle for sometime. Which year is this model? Quote
Zoom-Zoom Posted December 26, 2012 Author Posted December 26, 2012 No it was perfect before I changed the filter and this started to happen as soon as I changed the filter.2000 model. Quote
Rumesh88 Posted December 27, 2012 Posted December 27, 2012 Apologies for my misunderstanding. Changing the filter alone should not cause this problem. There is a non-return valve built into the fuel pump. Just check this by keeping ignition switched on for about 10 seconds before starting the car after keeping it parked overnight. If you can start the car immediately this way, then the problem is in fuel returning to the tank through the pump. Why was the fuel filter replaced in the first place? Quote
mazdaspeed Posted December 27, 2012 Posted December 27, 2012 There no harm, in fact it’s good you changed your fuel filter as it’s supposed to be changed at 80K. Besides with the high quality petrol we have and the fabulous sheds, you will be suppressed at the amount of gunk you get in the filter- I too replaced mine . I too had the same symptoms but it went away after the 2nd day. How long back did you change it ? The petrol pump could be blamed if it’s failing. You will need to see if the same give the correct pressure. I did not change mine, but so far no issues. 1 Quote
harshansenadhir Posted December 27, 2012 Posted December 27, 2012 Seems there is a lose tubing at either end of the filter. This cause air to seep through to the system and petrol will eventually flow backwards. Recheck the connecting points of the filter Quote
Zoom-Zoom Posted December 28, 2012 Author Posted December 28, 2012 Thanks for the support guys.I agree with mazdaspeed with the quality of petrol we have and the car just clocked 100K and my mechanic told me to replace it and he was right beacause we could see that the fuel was blackish and there was tar like substance in the filter, I believe that this was the first time the petrol filter was replaced. As Mazdaspeed said it was all fine on the 3rd day.Thank you once again. Quote
