upulhad Posted January 3, 2013 Share Posted January 3, 2013 On 12/27/2012 at 10:52 AM, Dinukap4 said: This might be out of the topic but With how much Amps does a alternator charge a normal 12V lets say 45ah Pb battery ? Like the Maximum Amps that a alternator is allowed lets say. http://brianesser.com/technical-information/alternator-wiring-diagrams-and-information/ Quote Link to comment Share on other sites More sharing options...
PreseaLover Posted June 15, 2017 Share Posted June 15, 2017 Hi Guys, I'm planning to buy a jumper cable from ebay or somewhere, so I just want to know how to check a suitable jumper cable for purchase.. its not only the cable i have to buy yes, and how to select the unit etc.? cuz there are jumper kits in that quick site for various prices... any advice on how to select a jumper kit? Quote Link to comment Share on other sites More sharing options...
The Stig Posted June 15, 2017 Share Posted June 15, 2017 On 6/15/2017 at 4:11 AM, PreseaLover said: Hi Guys, I'm planning to buy a jumper cable from ebay or somewhere, so I just want to know how to check a suitable jumper cable for purchase.. its not only the cable i have to buy yes, and how to select the unit etc.? cuz there are jumper kits in that quick site for various prices... any advice on how to select a jumper kit? Expand Jumper cables or kits? I bought a jumper cable from wow for around 1400 (i think). It's nothing complecated really, just get the thickest wires you can afford. As long as your battery is 12v35 or 12v45 most cables will be okay. Quote Link to comment Share on other sites More sharing options...
PreseaLover Posted June 15, 2017 Share Posted June 15, 2017 On 6/15/2017 at 6:52 AM, The Stig said: Jumper cables or kits? I bought a jumper cable from wow for around 1400 (i think). It's nothing complecated really, just get the thickest wires you can afford. As long as your battery is 12v35 or 12v45 most cables will be okay. Expand so the jumper cables should be fixed into a meter board or some kind of a gajet to get the power right? does it come with the jumper cables? whats the difference between the jumper cables and the jumper kit? Quote Link to comment Share on other sites More sharing options...
Rumesh88 Posted June 15, 2017 Share Posted June 15, 2017 @PreseaLover Jumper cables are just two passive copper wires thick enough to carry the cranking amperage (which is in the order of 300A) with two crocodile clips on either end to attach to battery terminals. You need to connect it to a battery of another car to jump start. Jumper kits on the other hand come with a battery bank to give your batter quick boost. Also included with them are other options like air compressor, torch etc. Both these have their own pros and cons. Quote Link to comment Share on other sites More sharing options...
PreseaLover Posted June 15, 2017 Share Posted June 15, 2017 On 6/15/2017 at 7:58 AM, Rumesh88 said: @PreseaLover Jumper cables are just two passive copper wires thick enough to carry the cranking amperage (which is in the order of 300A) with two crocodile clips on either end to attach to battery terminals. You need to connect it to a battery of another car to jump start. Jumper kits on the other hand come with a battery bank to give your batter quick boost. Also included with them are other options like air compressor, torch etc. Both these have their own pros and cons. Expand ohhhh got it, thanks for the explanation rumesh I found this jumper on ebay, which can be fitted into the ciggerette lighter... do you recommend this? http://www.ebay.com/itm/Car-Battery-Jumper-Booster-Start-Extension-Cables-Charger-To-Cigarette-Lighter-/111765267458?hash=item1a05baa402:g:~mkAAOSwu4BV7TP5 Quote Link to comment Share on other sites More sharing options...
MrCat Posted June 15, 2017 Share Posted June 15, 2017 Most cigarette lighters sockets are rated at around 120 watts. This means the socket should be able to pull 10A, possibly fused (maxed) at 15 or 20 AMPs. How that little jumper could start a car (even a small 4 cylinder) is beyond me.! You might be better off getting a set made using some good quality copper cable. I recently tried to start a 2.3 litre petrol GDI engine with a 400 AMP cable, the cable just couldn’t pull enough juice to start the car.! Quote Link to comment Share on other sites More sharing options...
Rumesh88 Posted June 15, 2017 Share Posted June 15, 2017 On 6/15/2017 at 8:24 AM, PreseaLover said: ohhhh got it, thanks for the explanation rumesh I found this jumper on ebay, which can be fitted into the ciggerette lighter... do you recommend this? http://www.ebay.com/itm/Car-Battery-Jumper-Booster-Start-Extension-Cables-Charger-To-Cigarette-Lighter-/111765267458?hash=item1a05baa402:g:~mkAAOSwu4BV7TP5 Expand This jumper is not for jump starting but to provide you with an external lighter socket so that you can use things like mobile chargers, lights, jump start kit battery banks (hence the wording "jumper booster start") that would otherwise need a car lighter socket. Quote Link to comment Share on other sites More sharing options...
PreseaLover Posted June 15, 2017 Share Posted June 15, 2017 On 6/15/2017 at 10:36 AM, Rumesh88 said: This jumper is not for jump starting but to provide you with an external lighter socket so that you can use things like mobile chargers, lights, jump start kit battery banks (hence the wording "jumper booster start") that would otherwise need a car lighter socket. Expand ohhh right, okay thanks rumesh Quote Link to comment Share on other sites More sharing options...
maersk Posted June 15, 2017 Share Posted June 15, 2017 ..or get something like this. http://www.ebay.com/itm/12V-80000mAh-Portable-Car-Jump-Starter-Power-Bank-Pack-Booster-Charger-Battery-/262418041051 1 Quote Link to comment Share on other sites More sharing options...
chathumal3000 Posted July 3, 2017 Share Posted July 3, 2017 Quote Link to comment Share on other sites More sharing options...
hassanmaalik Posted January 18, 2018 Share Posted January 18, 2018 Thanks for the tips. Would be helpful for people at some point Quote Link to comment Share on other sites More sharing options...
Autoz Posted May 3, 2018 Share Posted May 3, 2018 Here's a good info Quote Link to comment Share on other sites More sharing options...
