January 21, 201313 yr my cars power steering reservoir cap says "use dextron type ATF" it doesn't say whether dextron 11 or dextron 111. car is toyota carina AT 192. which type should I use..???
January 21, 201313 yr Dexron III is backward compatible with Dexron II, so you should be OK using Dexron III.
