Ishan Prasanga Posted June 25, 2013 Posted June 25, 2013 I have a Honda Fit Aria 2007 VTEC version car. Some times when i try to start the vehicle no ignition comes. After i move the gear to R and then moved to P Or N then it's do the ignition and engine starts. What could be the problem? Quote
MasterDon Posted June 25, 2013 Posted June 25, 2013 Might be an issue with the neutral safety switch.It's usually located at the base of the gear stalk.Have it checked. Quote
Uditha88 Posted June 25, 2013 Posted June 25, 2013 As Don said, most probably issue with switch located on transmission. If that not the case, service starter motor. Quote
Ishan Prasanga Posted July 1, 2013 Author Posted July 1, 2013 thanks. i'll check on the switch. I just bought this honda fit aria VTEC version. Last time, i full tank on petrol and run in colombo normal traffic until end of fuel. it does close to 8. (7.8) i wonder on this low fuel consuption. I heard lot on honda fit aria where it does 10-11 in traffic if it's a VTEC and 12-13 if it is iDSI. Already i changed the CVT oil and engine oil too. i checked the plugs and air filter too. all are fine. what could be the problem? is i need to do a engine tune up from a honda expert?? Quote
