October 22, 201313 yr Author Yeah. They're all season tires, not really winter tread .. but still better than summer z-rated that turns into plastic in the winter lol
October 23, 201313 yr Author Cut the studs down a bit bzzzz.... bolt on the spacers... Tadaaa!!! Still gotta do the rears... Since I didn't have the rears done, I left them on the front and put the stock wheels back on ... I think I like the stance now! ... maybe a bit too far, but I know what offsets I'd want in my next set Edited October 23, 201313 yr by Mean Green z28
October 24, 201313 yr Author A little bit more cutting... and the rears are a bit too wide with the stock wheels on spacers...lol ... they'll be fine with the other rims.
October 25, 201313 yr This might be a bit of a stupid question, but when you cut the studs, will there be enough thread to safely hold the lugnuts on your regular wheels ? Edited October 25, 201313 yr by Watchman
October 25, 201313 yr Author Def. not a stupid question. If you look closely at the pics, you'll see that the first bit of stud doesn't really have any thread on it and mainly just tapers to a point; probably to ease installation. Some of that unthreaded portion is what we cut off and never got close to the threads. Edited October 25, 201313 yr by Mean Green z28
October 25, 201313 yr Ohh I see, I thought the thinner diameter section was filed out by you as a marker. But come to think of it, its a pretty simple and smart idea cos its not uncommon for the lugnuts to set off the thread when changing wheels. .
October 25, 201313 yr and the rears are a bit too wide with the stock wheels on spacers...lol ... they'll be fine with the other rims. That's gonna suck for winter driving Mean Green: There's going to be salt spray all over the rear panels of your car...
October 25, 201313 yr Author Kavvs, those are not the winter set mounted, they sit inside the fenderwell ... that pic is of the stock wheels and they're wider; they were just a test fit to see how it fit, I'm not running the spacers on the stock rear wheels. Edited October 25, 201313 yr by Mean Green z28
October 25, 201313 yr Kavvs, those are not the winter set mounted, they sit inside the fenderwell ... that pic is of the stock wheels and they're wider; they were just a test fit to see how it fit, I'm not running the spacers on the stock rear wheels. Ah I see, my bad...
December 23, 201312 yr Author Installed a Cold Air kit... ... and a cold air scoop and washer fluid bottle relocation kit (due to the location of the scoop)... The air scoop directs air from the lower front opening. Pic is with the inner fender liner removed. Edited December 23, 201312 yr by Mean Green z28
December 23, 201312 yr Confused. That's the same cone right? So you've got a lotta space behind your quarter panel? Is that how it's fitted? And also, such a big engine I thought had one intake for each bank?
December 24, 201312 yr Just honest questions bro. I admit I fap to your car when ever you post a picture. And seethe with jealousy. Shamelessly!!
December 24, 201312 yr Author Lol Yeah its the same cone filter from top and bottom. There's quite a bit of space in the fenderwell behind the headlight. Previous gen had a lotmore though.. As for the inlet tubing, its 4" tubing and is good enough for a naturally aspirated car without much internal/head work done. Edited December 24, 201312 yr by Mean Green z28
September 10, 201412 yr Author update! Bought a set of LED taillights for the car. Got them locally from a guy but they came missing a harness. Ordered it from the manufacturer and waiting. They'll look like this once installed... All in, I'd have spent $126 total instead of $399+shipping ... lol, Iove good deals Edited September 10, 201412 yr by Mean Green z28
September 10, 201412 yr would you beleive they made these for the 510 SSS JDM variant back in 1968? only thing is they used a mechanical relay with a cam instead of solid state circuitry. planning on getting a circuit for mine. but then i need to convince a certain autolankan to sell me the spare relay he has.
September 10, 201412 yr Author you could also just use a timed relay like this ... http://www.amazon.com/PowerArt-Switch-Adjustable-Module-Electrical/dp/B00CRYUSR2/ref=pd_sim_e_1?ie=UTF8&refRID=1YK5Q1FYANBGEF7KHQYW#productDetails That was what I was gonna use on my outer lights before I found these Edited September 10, 201412 yr by Mean Green z28
