Hi everybody,
first i should thank everybody who post in AL that make many people educated.
I have a year2000 Honda City for more than a year, its a nice car that gave me no trouble but recently i found that there's an OIL LEAK from the Rack End.
I read that post about Rack end oil leak of that cefiro, but got no clues about Honda spares..
please need some advice where or how to get it fixed..
regards..
My 96 Ek3 also has the same issue, slight oily look in both ends of steering rack but no noticeable oil level drops in power steering oil tank.
A few mechanics told no point of replacing oil seals and all, it needs to be replaced with a recon rack.
And recently I noticed a sound which is similar to bad CV joint sounds when steering is turned both ways while car is moving only, but no sounds when moving straight. I checked both CV boots were not damaged also.
I also read the previous thread about Cefiro and got to know that Komisiripala has helped the victim. Can you do the same to me too before I ended up replacing the rack?
Many Thanks.
Cefi's one seems to be holding for now. I'm waiting to see how good the repair is. Check your inbox.
Thanks for the info. I will have a check with him, once I went there. Will see how it goes.
