Honestly like Rumesh said any monkey with a wrench and some gasket sealer can replace the valve cover gasket. You could have adjusted tappets also while this was done if it was done at a normal joint.
5 hours ago, Rumesh88 said:
This is what happens when you try to use a guillotine to clear your dandruff! Replacing cam/rocker/valve cover gasket (or packing in local jargon to avoid confusion with the head gasket), T-belt/tensioner, water pump and alternator pulley in an engine like yours (must be a 5A-FE or 4A-FE engine) does not need the expertise of an agent. Also all this must have left quite a deep hole in your pocket :D but for me it leaves some doubts whether the job was really complete. When there is a leak in cam cover packing first thing to do is to check the PCV and clean the oil baffles along with changing the gasket. I do not think you are aware if this was done or not. This is a disadvantage when you get the repair done at the agent because you are not allowed near the car.
It's a 2AZ-FE, yes agreed, the lesson I learned is the mechanics at the agent's can be of inferior quality.
I actually had the PCV valve checked for blockage because I detected some blowback, however you are right, I don't know whether they cleaned anything (I really really doubt it).
81K deep hole :angry:
I didn't knew/still don't know any really good garages for engine work, most place I asked haven't really worked on a Camry, so I stuck to the agent until this incident.
I need the front stabiliser bars replaced along with the bushings, so going to get this done from the outside (already had the genuine parts shipped over).
@Thihara Is it a Camry then (Sorry I missed it)? If you indicate where you are located someone on the forum would be able to help you with a recommendation for a mechanic.
Edited by Rumesh88
@Rumesh Nope it's a 2007 Camry. I ended up buying that after getting feedback from this Forum, before I was set on a Geely :D
I'm in Kandana. I'd appreciate if anyone can find me a good mechanic nearby, or if he's really good, even in Colombo.
