What Are The Engines, Can Replace 4D56 Engine?
I want to replace 4D56 engine of my L200 (manufactured in 1987) with engine that have better performance. So what are the engines match with L200 ( My budget is 200,000/-)
10 answers to this question
matching one with better performance would be 4M40T as it can go into L200 with minor modifications. Intercooled turbo charged with 2.8l, hence better performance than 4D56 (N/A 2.5l).
However, 4D56 is a better engine than 4M40T in terms of reliability and wear and tear. Therefore, you can consider 4D56T (turbo charged, 2.5l) as well.
Thanks..As i'm not much familier with technical aspects of engines, pls help me....
whether brandnew 4D56 (turbo charged, 2.5L) available or not?
or reconditioned (YoM...?)
brand new? in SL ? most likely not and even if available (through agents) it'll cost a fortune. Turbo charged 2.5L (4D56T) came along with Pajero V35 (as known as computer body in SL market) so you should be able to find a used one imported from elsewhere.
Hi, this sounds interesting. What exactly do you mean by better performance?
If you intend to make it more capable off road, there are better places to start than an engine swap (provided there's nothing much wrong with the existing one). Or is the engine shot and you're simply thinking of going for a better engine rather than replacing it with the same engine mdoel?
go for a 4D56 with a turbo, recon engine from a palath saba pajero - easiest way
acording to my knowledge, that need some modification to the gear box, but this is what most L200 owners does
if you are lucky, you might find a 4d56 turbo charged, removed from a strada ....... very rare ( and expensive) then it s a direct fit
i have seen few palath saba pajeros repalced with 4m40s but majority are failures, but no L200s
check the engine room size and the mounting places of your vehicle wether it can accomodate a 4m40, but it need a huge modification i suppose
diesel engines are costly these days....... (somebody told me that 4m40 is cheaper than 4d56 these days)
you may not be able to upgrade a 1987 YOM vehicle up to the standered you expect
also in my experience most Mitsu diesels built during that era are with less pulling power when it s compared with a Toyota
so buy a toyota with that 200,000, if you are really worried about the power
Edited by priyanka
coputer body model spares are rare but v44 (with 4d56) is there everywhere
and v 35 is petrol swb i guess
Edited by priyanka
I also reccomend the 4D56 Turbo.Having lived with my Strada for nearly a decade I can safely say it's a pretty solid engine.Can be pretty hard to find one though.Stay away from the N/A version it lacks the grunt and takes a lot of revs to get going.
I dont think its possible to fix Pajero's engine to a Strada even though they both have the same model engine. Just check with spare parts shops
ok friends...I think to purchase Mitsusishi Pajero Engine...so where can I find them at reasonable price...tell me reliable place pls?
