Nissan Pulsar Cj1 :how To Increase Ground Clearance
Dear All,
im facing driving difficulties due to low ground clearance in my car.current OEM RIM size is 175/70 R13.
​for better ground clearance do i need to change shocks ?/Or higher tire size 195/55 R15?please advise
Nissan Pulsar Cj1,YOM-1998,FN15
can i use 195/55 R15 with my car?(please check below web link they said i can use 195/55 R15)
http://www.wheel-size.com/size/nissan/pulsar/1998/#trim-fn15
Tires for Nissan Pulsar 1998
  • Diameters: 13'' - 15''
  • Width (mm): 175 - 195
  • Tire aspect ratio (%): 55 - 70
  • Smallest tire size: 175/70 R13
  • Largest tire size: 195/55 R15
Tire Rim Bolt pattern THD CB 165SR13 5x13 ET40 4x100 N/A 175/70 R13 5x13 ET35 4x100 N/A
Please advise...
Wow my dad has the same car and I felt it had amazing clearance! Relative to what I drive.
You better best not mess with suspension geometry trying to "raise" your car. It's going to change the handling characteristics, and give you a positive camber with uneven tyre wear.
Maybe a change of car? Swift jeep model? A small jeep? Might be better suited to your needs
Edited by Komisiripala
Dear All,
Please advise...
Going for 195/55 R15 won't raise the ride height. It will keep it exactly the same if its factory spec, but just make the ride a bit harsher and the handling a little better.
Changing ride height is not a great idea, unless you are going to invest in all the adjustable suspension arms etc to correct the suspension geometry afterwards.
sorry for late reply,,,All your comments are highly appreciated. why im planning increase ground clearance of my car...some time when i driving through road bumpers car engine/chassis hitting the road bumper(even with slow driving).
Thanks "the don" @ http://www.etyres.co...size-calculator
165:70:14 Difference in diameter =2.09% so with this can i increase my car ground clearance?Please advise
HI nimz my previous fb14 had 175/65/r14.(original was same as yours 13)Had no ground clearance issues even with 5 people over a bumper.But a considerable amount of road noise and harshness were introduced.If your car is getting bottom out that bad check your suspension and coil springs too.springs get weak over time.Checking your spring stiffness will be a good idea.If it's too soft go for stiff ones.
Here is a pic so you can compare the height of your car to mine.
Edited by GayanR
This is sort of a common problem with Nissans of this age.
my previous FB14 was scraping everywhere i go
finally got fed up and change to 14" rims with 70/175 tires and that helped alot
i travel in some very bad roads so i can say this helps
402067_3258050328514_1015268192_n.jpg?oh
That said the down side of this is that the speedometer calibaration will be off so you will have either re calibarate (if possible) or keep in mind that your going a tiny bit faster than what your speedo is saying
reffer the link
http://www.tacomaworld.com/forum/tirecalc.php?width1=175&ratio1=70&rim1=13&width2=175&ratio2=70&rim2=14
thanks for your comment..im just asking
175:70:14 Difference in diameter =4.4% ...but this should be +/-2.5% for better output?
reffer the link
Wow,,thanks lot for both :)...Schiffer and GayanR....please let me know where i can test spring stiffness?any good place..
planning to change with 175-65r14
Edited by Nimz77
yes when considering those calibrations and all its better if the difference is low. but even with this set up there were few times my car got scraped but not as much as before. so for me practicality came first
