hatharasinghe Posted July 28, 2014 Posted July 28, 2014 Sometime this information will help to you , if you use Kia Spectra, Hyndai Accent ect... or sometime this may happen to any other models also. I already post this matter 2 yrs ago and got lot of technical ideas but couldnt get exact result. I had a Kia Spectra car and once i drive long distance (i go Badulla lot of weekends from Kiribathgoda) once i drive more than 100km then suddenly there was a problem the car is not moving fast though i push the Accelarator sometime speed under 40Km/Hr .And if the car stopped for a 15min then drive again can do normal drive at least another 10KM and again the problem started. So below repairs done. 1.Replace Injectors 2.Engine Tune 3.Ignition Coil 4.Checking all the fuel line and cleaning fuel filter and pump 5.Throttle body And lot of relating repairs done at famous garages and company. But no improment this only happen only after 100 + KM drive .No one could find the exact answer. Finally one garage guy at Badulla told me after hearing my story , he had previous experiance all Korean Vehicles fuel pump get problem on after some years specially the inside coil will not able to produce necessary action to function the fuel pump properly when it heatup pump works out of normal funtion. So replaced it with Japanese good one and after that nothing wrong and driven it as before. Hope if anybody suffer this kind of matter pls check this pump. Normal condition it works but after get heated its not working properly. Quote
NRX Posted July 29, 2014 Posted July 29, 2014 Appreciate that you took your time to post the end result. So nobody checked the fuel pressure before ? :/ Quote
hatharasinghe Posted July 29, 2014 Author Posted July 29, 2014 Appreciate that you took your time to post the end result. So nobody checked the fuel pressure before ? :/ several famouse garages checked no one could find it as it happen after long drive in normal condition nothing wrong once i drive around colombo areas normally 20km up and down then nothing wrong at all .some garages kept the car couple of days to check but couldnt find. and some expertise who appear on TV also couldnt find. Quote
Clark's son Posted July 29, 2014 Posted July 29, 2014 This is a problem with the hyundais which where imported from sigapore in the 2000s right, the 15yr old rios accents spectras ect... Quote
Crosswind Posted July 29, 2014 Posted July 29, 2014 No it prevails in newer cars too. I had the same issue in the 2011 cerato. Its due to substandard petrol in sri lanka. My very non-famous roadside mechanic picked up the issue in one go, so it wasnt a hassle. It seems japanese fuel pumps tolerate substandard petrol better than korean ones. Quote
Clark's son Posted July 29, 2014 Posted July 29, 2014 No it prevails in newer cars too. I had the same issue in the 2011 cerato. Its due to substandard petrol in sri lanka. My very non-famous roadside mechanic picked up the issue in one go, so it wasnt a hassle. It seems japanese fuel pumps tolerate substandard petrol better than korean ones. Good to know that, Our santa's (santa fe) drinking super diesel since she was born, no hiccups yet for 7 years, hope nothing goes wrong with our diesel Quote
MAS Posted August 1, 2014 Posted August 1, 2014 Hi Hatharasinghe, What was the brand of the Japanese pump you brought? was it a direct fit? price? shop? Quote
Crosswind Posted August 1, 2014 Posted August 1, 2014 Good to know that,Our santa's (santa fe) drinking super diesel since she was born, no hiccups yet for 7 years, hope nothing goes wrong with our diesel Out of curiosity, how much diesel does she drink? Quote
Clark's son Posted August 1, 2014 Posted August 1, 2014 Out of curiosity, how much diesel does she drink? Now it does about 16kmpl long run and about 10kmpl short, it's the manual 5seater one. It did better when new. Quote
