Removing Paint Dots
Hi All,
There were few paint dots on my car bonnet when i came from a party last night. Like it was
sprayed by a paint brush.
Just need a quick solution to remove them by myself..Thanks in advance
Sri
6 answers to this question
i have removed paint drops using rubbing compound, give it a try but make sure you dont use too much force or you will end up damaging the paint
Thanks...There are many tiny drops all over the bonnet and few on the windscreen as well.. I will try this but little scare of it..
Once I wiped some dots / overspray with diesel, requires a bit of elbow grease, no issue with the underlying paint, one can get carried away with rubbing compound you know..
Try Diesel as said. Actual pain shops use brasso which is a fine rubbing compound. Remember get fine compound if you get it. Else use standard car polish.
