3 hours ago, Axela_lover said:
Thanks.. by looking at the comment session in this video also it seems too early and have some risk involve on playing with Android auto..
Bluetooth not working to Brick the entire system..
Best thing I guess is upgrade the Maps which I did last week. The maps are working in Colombo perfectly and I see more than 4 satellite connections most of the time.
It gives the HUD and voice navigation which is also a cool and supported feature which we never discover before.
It's worth for the money  ( took 20k for me) and I see no problem as one mentioned earlier..
Sounds cool, I am going to install the maps.
Android auto is great but I think it's still early stages to give it a try, hopefully Mazda will officially release it to every single model soon. Fingerscrossed :P
Next Gen Axela with HCCI will be introduced this fall
According to this roadmap it will kill Toyota HSD.
Mazda will introduce inhouse mild hybrid!
I guess it will be revealed in Tokyo Motor Show Oct!
Hopefully the come up with a 1500cc hybrid setup!
Edited by zeem35
  • 3 weeks later...
Hv u done ur Map installation? Mine work perfectly fine..
got to know that the new maps coming in 2017 Proactive can't be change with old maps..
Not yet machan, I will do it in september, I'll update this post.
  • 2 months later...
Now Android auto is fully functional and there's a patch for Bluetooth bug. Just need to run the patch with existing AA . I've installed some extra apps like speedometer with compass which is really nice to have.
Dear H.C. I saw you have posted a few photos of your newly purchased Axela on FB. If you don't mind, will you please post more photos here as well?
  • 4 weeks later...
Sorry mate, I didn't see your post. I'll add few photos
Edited by H.C
Looks cool bro. Did you test the I activsense safety features?
Yes. They all activate by default in startup. Really useful,especially auto headlights which selectively turn off for incoming vehicles,even for a motorbike.
  • 7 months later...
On 5/31/2017 at 8:39 AM, Quiet said:
The guy who advertised on Navi installation came yesterday. He wanted to do a software update as well with some new software such as the RPM meter, Android Auto etc etc. I just installed Mazda Navi and it has three free updates. He has converted his Axela 2016 to English with all those software updates.
So if any one with Axelas with Jap. language, it seems possible to convert to English.
On 5/31/2017 at 3:42 PM, Quiet said:
Its 0777565884
@Quiet I tried to contact this number. But I was unable to contact. Any information pls.
Sorry nirosha the guy migrated few months back
Too bad. I called S*n L*nk* too. They can't do it to stock player. @CM it is Rs. 85,000/-.
If you are happy with android auto, its a DIY job. Same guy did a firmware update and sold me a SD card with Asian maps which did not work(Its a cloned SD card,which he sold me as a brand new one). you can install several interesting apps like speedometer( with parameters like intake temperature, coolant temperature, battery voltage, fuel consumption,GPS data,Etc..) by yourself ,but do go through Mazda3revolution.com  forum . All the installation files are available at mazdatweeks.com for free which was used by the above mentioned guy for installation.  If your firmware version is 59.000.502 and above , you cant install above tweeks as Mazda has blocked the USB access to prevent hacking.
Yup. I went through these websites. But sadly the firmware version is 59.00.502 ?. Also tried Smart MZD player. But it also did not worked.
Sorry to hear that. what did colonial people say about navigation. According to the facts from Mazdarevolution forum, Japan uses separate sat nav protocol to the rest of the world. I've bought a brand new Asian map containing SD card from ebay, but no satellites were detected in navigation. However GPS coordinates,altitude, compass works in other apps. Did you fix a reverse cam?. I got a genuine Mazda wide angle cam from Mazna motors.( I got to know this from my car importer which happens to be the  same guy which imported yours! )☺️
Edited by H.C
Well CM says it is possible to use SL maps with the JDM cars. Only thing is the price. Its 85K.
I have a reverse cam from a friend of me. But did not fixed yet. Cz I don't like to cut original wiring and drill the car to fix the cam. And had no time to look after it.
BTW how much did they charge for the cam fixing? I am thinking of 360 cam than the reverse cam (and fix to the original player. And S*n L*nk* is unable to fix it to the original player.). Cz you know these bikes and 3wheelers are giving enough headache.
My imported told me that he is going to bring down fog lights for a Mazda Axela. Is that for you? ?
If you can find a OEM Mazda 3 or Mazda 6 cam, its plug & play. All the wiring is there. You have to remove the plastic nobs from the boot cover and remove the plastic cover which blocks the cam mounting place. Then you have to reset the system by removing the battery negative terminal. They got 2000Rs as fixings charges.  For me, with blind spot monitoring, rear cross traffic alert with headup display warning signals and side mirror indicators are more than enough for bikes and three wheelers.  Also add the beep signal in vehicle settings (Audio + Visual alarm).  He said he will try to import fogs. If you can reach Horana with a OEM cam I can fix it for you. Have you changed the language in the MZD connect?
Sorry for the delayed reply. I am hunting for a good cam these days. I also prefer an OEM cam. Thanks a lot for your support and offer.
I also configured all the warnings and alerts and it is working great in traffic. I have changed the language to English. But in HUD unit some warnings displayed in Japanese. Also on the Dash below the temperature a Japanese word is there.
I am looking for a good dash cam. Best I found is at the moment is Viofo A119C. But sadly no wifi.
BTW I found that floor mats are very cheap (23 pounds) in Mazda UK site (CM asked me Rs. 25,000/-). Thinking of importing the same.
I got my reverse cam from Mazna.  Most of HUD warnings appear in English. I only get warning in Japanese when Im nearing a T junction.
Im having the Viofo 119c for more than a year now and its really good. Luckily my one came with OEM floor mats . I've bought bootlid spoiler, window wiser, and Scuff plates via ebay as they are not available locally. Also got a brand new map SD card for 60$ which is not working with my current firmware. Planning to change the firmware to latest ADR ,which may allow me to use the Asian maps.
Thanks a lot. If you can pls share the links.
Map SD for USD 60 is dirty cheap. Is it an original one? My stock SD not working at all. It keep restarting the head unit in every few minutes. After the removal it works fine.
Also pls share the firmware upgrading process.
On 6/19/2018 at 7:11 PM, Nirosha said:
ou? ?
Following are the basic steps to change/upgrade the firmware of 2014 upwards Mazda 3/Axela/6/CX 5. For the older firmware , its a two step process as you have to first upgrade to version 31 and upgrade to latest version. Anyone attempts to upgrade need to read the installation instruction thoroughly, as one wrong step may result in a bricked unit. I've got following steps from mazda3revolution forum, which helped me to upgrade my vehicle(JDM Axela 2016) firmware to latest one issued at Colonial and allowed me to use the Map SD which I bought from Ebay for 60$.
2018 Connect UPDATE Procedures Worldwide
1. Note or copy set favorites in (AM / FM, etc).
2. Turn off the ignition (Off) !
Note: All electrical loads during reprogramming must be switched off,
especially air conditioning (fan blower), rear window heating, interior lighting and cars ENGINE, ALL Turned Off !.
3. Remove the Navigation SD Card of the navigation system (if car is equipped with navigation).
Remove any other/all connected USB Devices, otherwise the CMU will be damaged.
Note: During CMU re-programming, no card may be inserted in the slot for the SD Card of the Navigation system be introduced.
4. Insert the "ROOM" and "AUDIO" fuses into the fuse box in the engine compartment (if not already done).
5. Connect a battery charger (charging current 4 - 5A) to the vehicle to Compensate for voltage fluctuations (optional 'if' car Battery is weak or old).
6. Press the engine start / stop button ONCE without the clutch pedal (manual transmission) or to depress the brake pedal (automatic transmission) to apply the ignition to ACC.
ONLY Amber/Orange lamp should be on inside the Round Stop/Start Button, No Instrument Cluster (IC) lamps should be on and No Green lamps on the Start Stop Switch.
Note: The engine will start when the start button is pressed with the clutch pedal depressed (Manual transmission) or brake pedal (automatic transmission) is also pressed at same time.
DO NOT WANT ENGINE RUNNING.
NOTE: If the ignition remains in the ACC (Amber/Orange) position, IT WILL TURN OFF after 25 minutes automatically.
Stay ON by pressing and releasing the clutch pedal (Manual transmission) or the brake pedal (Automatic transmission) before the end of the 25 minute cycle, the timer is then reset.
This will ensure that the power supply to CMU during the Re-programming flashing is not turned off.
THIS IS CRITICAL, IF 'CMU' TURNS OFF DURING ANY UPDATES IT WILL BE BRICKED.
Suggest use a small 'timer device' like egg timer to remind operator to press Brake Pedal every 20 minutes to prevent CMU from switching off.
NOTE: If car is an Automatic, leaving the Shifter in N (Neutral) will keep CMU alive, make sure car can not roll or move (place wheel Tire chocks/rock/brick to prevent car moving).
NOTE: If car has an Electric Park Brake (on Console Toggle Switch) do not engage or turn on (place wheel Tire chocks/rock/brick to prevent car moving).
7. Select the radio function ON (AM or FM) and make sure the speakers function/work.
If no sound is heard, turn up the volume control (A) or check that the Mute IS NOT activated.
NOTE: When the speakers are working, the CMU system is in standby mode which is correct for updates.
8. Press the three buttons (Music (A) + Favorites (B) + Volume Mute (C)) on the Commander rotary-push button press simultaneously for 2 to 5 seconds for the Diagnostics 'test screen' to appear on touch screen in black and white.
9. Enter "3" on the test screen, then select "ENTER" to check whether fault codes (DTCs) are stored (in the CMU). Select "CLEAR" and go to the next step.
10. Regardless of whether DTCs are stored or not, on the Enter test screen "2", then select "ENTER".
Select CLEAR for previous stored (in CMU) DTCs internally cleared.
"EXIT" select and go to the next step.
11. To finish the trouble codes clearing process, turn off the ACC ignition (press Start/Stop button), Remove the key(s) from the vehicle, Windows up and lock all doors, walk clear and wait 5 minutes.
12. Re-open the vehicle.
13. Press the engine start / stop button once without the clutch pedal (Manual transmission) or the brake pedal (automatic transmission) to operate the ignition on ACC to Amber/Orange.
Again confirm that Sound can be heard from Radio, so system is ready and in stand by.
14. Connect the prepared USB memory stick to one of the two USB ports.
Note: ONLY the prepared Quality Branded USB memory stick may be inserted in one of the USB ports.
During reprogramming, nothing should be allowed to the other USB port.
During reprogramming, nothing should be allowed in the SD Card port slot.
15. When the USB memory stick is detected, the following message appears briefly on the Screen.
USB1 ''USB Flash Disk Connected''.
Note: If the USB flash drive is not recognized, go back to step 11 and repeat forward. Or you may find you need to try a different branded USB Flash Drive, some owners have tried up to 4 different USB Flash Drives until CMU confirms seeing your .UP files.
16. Press the three buttons (Music (A) + Favorites (B) + Volume Mute (C)) on Press Commander rotary push-button again simultaneously for 2 to 5 seconds.
17. Enter "99" using the touch screen or the Commander rotary push button, then press On the test screen, select "ENTER".
18. On the next following screen, select "Search".
19. First select "Fail Safe Package" on the touchscreen.
Attention: Always select "Fail Safe.UP Package" FIRST, the software version numbers should also be shown.
20. On the next following screen, select "Install".
New Screen says "Installing Fail-Safe system update'' with a progress bar is shown.
Once Completed 'Install Successful' and 'No reboot required' select ''OK''.
Note: DO NOT Re-Start car or system, DO NOT Re-Boot or turn off system even if asked to do so.
21. Press the clutch pedal (manual transmission) or the brake pedal (automatic transmission) to keep CMU alive.
NOTE: If the ignition remains in the ACC (Amber/Orange) position, IT WILL TURN OFF after 25 minutesautomatically. Stay ON by pressing and releasing the clutch pedal (Manual transmission) or the brake pedal (Automatic transmission) before the end of the 25 minute cycle the timer is then reset.
This will ensure that the power supply to CMU during the Reprogramming is not turned off.
NOTE: If car is an Automatic Transmission, leaving the Shifter in N (Neutral) will keep CMU alive, make sure car can not roll or move (place wheel Tire chocks/rock to prevent car moving).
NOTE: If car has an Electric Park Brake (on Console Toggle Switch) do not engage or turn on (place wheel Tire chocks/rock to prevent car moving).
This will ensure that the ACC is remains on during the installation of the Re-Install.UP package is not turned off.
22. Press the three buttons (Music (A) + Favorites (B) + Volume Mute (C)) on the Commander rotary-push button simultaneously for 2 to 5 seconds to press the Diagnostic test screen to reopen.
23. Enter "99" using the touch screen or the Commander rotary push-button, then press 'ENTER' On the test screen.
24. On the next following screen, select "Search".
25. On the following screen, select "Reinstallation Package".
The actual Software Version number is displayed.
26. On this Install screen choose 'Install'.
27. Next Screen will say "Preparing to update....."
Note: For a short time a blank screen (black and or white) are momentarily displayed.
It takes about 4-6 minutes before during the flash reprogramming the next Screen appears.
28. The progress re-installation bar starts at 0% and the progress bar runs during the Re-programming slowly to 100%. This can take up to 60 minutes. Time taken depends on your Country Type/Version being installed, NA N is the quickest, EU N takes the longest (Larger File).
Note: So that the power supply (Position ACC) during the Re-programming does not turn off, touch the Clutch pedal (manual transmission) or the brake pedal (Automatic transmission) once is required before the end of 25 minutes, press and release.
DO NOT TURN ENGINE OR IGNITION GREEN LIGHT ON, IT WILL DAMAGE CMU.
Note: Because the screen is darkened, it is under difficult circumstances for screen reading. The message "Do not restart vehicle at this time" The current (Do not restart vehicle now) Software version however is displayed during the Re-programming.
Note: It takes some time for reprogramming to progress from 98% to 100%.
WAIT and WAIT Again DO NOT turn on the ignition/start car to avoid damaging the CMU.
And Do Not Turn OFF the Ignition if it is taking longer than 60 minutes, see below.
After the install of the final Re-Install.UP file the Touch-screen should say....
Version xx.xx.xxx software install was successful.
Please restart the vehicle for changes to take effect.
Yes, if you see this screen you can Power OFF (Press Start Button ONCE), Leave the USB Stick in for now, wait 20 seconds, and then Power ON (Press Start Button ONCE to Amber-Orange).
After CMU Re-Boot/Re-Start, WAIT, in time one of the following should be Touch-screen displayed....
Type A: The Normal 'Warning against 'Distraction' and an 'I Agree' red touch bar', then in this case reprogramming is already completed....Mazda 'wing' logo, etc.
Then Continue with step 30.
Or...
Type B: The ACC Power Supply went OFF during re-programming.
Below is displayed on screen until reprogramming is completed.
After completion of the re-programming continues with the next steps.
Provided CMU has not been fatally damaged.
Continue with step 29.
"INSTALL NOT SUCCESSFUL: SYSTEM FAILURE"
MAKE SURE THAT THE USB WITH UPDATE PACKAGE IS INSERTED.
THE SYSTEM WILL AUTOMATICALLY RETRY THE UPDATE.
29. Check that the indicator light in the start / stop button is lit (Amber/Orange) and the Instrument cluster Display is still off.
If the ignition is off (OFF) and the indicator light in the start / stop button IS NOT lit (Amber/Orange is off),
set the ignition to ACC (Amber/Orange) again....DO NOT START CAR or turn Ignition onto Green light.
(Keep foot off Brake or Clutch pedal until ACC is set to Amber/Orange)
::: If the reprogramming is not completed :::
When the screen turns white or black or freezes after the task-bar is displayed the completion screen is displayed, perform the following steps after 60 minutes (approx).
a. Switch off the ignition. (Do not start the engine.)
b. Wait for the screen to turn black.
c. Remove the USB memory stick.
d. Remove the fuse "ROOM" (and ''AUDIO'' if equipped) Fuses and wait 2 minutes.
e. Reinstall the fuse "ROOM" (and ''AUDIO'' if equipped) Fuses.
f. Set the ignition to ACC (Amber/Orange), DO NOT Start Engine or Green Light (Engine Ignition On).
g. Check that "INSTALL NOT SUCCESSFUL: SYSTEM FAILURE" Warning appears on screen.
h. Connect USB memory stick to the USB port.
i. Check that the task bar appears.
j. SYSTEM will or should Automatically Re-TRY Update files.
If successful the ''Warning'' against 'Distraction' and the 'I Agree' touch bar, then reprogramming is completed....Mazda 'wing' logo, etc.
30. Turn off the ignition and remove the USB memory stick from the USB port.
31. To stabilize the system switch off the ignition, remove ALL keys from the the vehicle, windows up, lock all doors and move away from car for 5 minutes.
32. PC update Navi SD Card via latest MAZDA TOOLBOX ''Before'' SD Card is Re-inserted.
33. Reopen the vehicle.
34. Insert Updated Navi SD Card.
35. Press the engine start / stop button once without the clutch pedal (Manual transmission) or the brake pedal (automatic transmission) to operate the ignition on ACC...DO NOT START ENGINE.
36. After the Connect system has started, wait 2-3 minutes without any input so that the Configuration is completed. (The ignition can be switched on and that Vehicle can now be driven.)
37. Check the screen install software version to make sure it's the same version as the one on the USB memory stick.
The navigation screen..
Call up and check that the current vehicle position is screen displayed correctly.
If the Vehicle position is incorrect, check the GPS reception and take the vehicle a short Drive at least 15 km.
Note: Before attempting to pair a phone with the system, DELETE 'MAZDA' from the list of Bluetooth devices on the actual phone to be paired with the system.
Because if this is not done, the phone CAN NOT be paired with the Connect system as the phone does not auto overwrite or remove the old Bluetooth link inside phone.
38. Disconnect any battery charger from the vehicle (if used).
39. Set the language back to the desired national language.
40. Reset the noted stations (AM / FM).
41. Turn off Car.
Click image for larger version  Name: 2018.jpg Views: 50 Size: 8.2 KB ID: 250985
