Hi Guys,
If you are using a cool box (Not the one came with the car) could you share the details.
It seems they use at least 3 AMP or higher continuously to keep cooling. When it is being used,
  • Do we need to keep the engine running to provide the power needed?
because otherwise the battery will be drained.
  • Do you get 0 °C (Zero) and how long does it take to get zero?
  • Could you suggest a brand / or what's yours brand?
Appreciate your replies. Thanks.
3 answers to this question
http://forum.autolanka.com/topic/15992-electric-cool-boxes/?hl=refrigerator#entry260160
If its thermoelectric/ Peltier, in a practical setting in our country, I'd doubt you'll get below 15c
Unless you have a dual battery setup, a 3A draw is likely to drain your battery overnight,
it will be harmless for 1-2hours with the engine off, separate fused power via a switch is better than acc, or ignition switch as there is a draw further from the cars electrics, via provided the car starts easy.
Edited by tiv
What would you suggest if the temperature need to be reduced below 15c? For that case thermoelectric/ Peltier coolers won't be effective isn't it? (As the difference is like 20c? )
Yes, read the linked post, it was discussed a bit there,
It terms of cooling capability the a/c compressor cooled system(built-in coolbox) is ahead.
I was told however if a if a coolbox / refrigerator was fitted from the factory, the compressor is specially equipped to handle a coolbox, therefore if you retrofit a coolbox to a particular vehicle, you need to upgrade it to the correct capable compressor, otherwise the existing compressor with fail in a short period due to excessive load.
As for the thermoelectric cooler, I have used a Toyota branded unit, an OEM upgrade for the Hilux / Fortuner from Thailand, this too couldn't get below 10-15c
However it can hold a canned drink etc cool enough, forget ice though.
Plugs in to the 12v port.
