gsumithm Posted June 3, 2015 Share Posted June 3, 2015 Need help from experts & owners who experienced same situation before.My car is Kia Rio(2003 model) Continuous rattling noise came from engine bay from compressor and it was compressor clutch plate.As suggested by A/C technician I replaced,1.Compressor clutch plate 2.Pulley assembly 3.Bearing 4.A/C hose (since there was a leak-confirmed by dye test) 5.Filled gas Now I've noticed that the AC will no longer blow cold air if I've been idling too long (either parked, sitting in traffic, at a long traffic light, etc.) Once I start driving again, it cools back down like normal. Now technician is suggesting me to replace compressor which will cost me 17,500/- (reconditioned), 34,000/- (brand new) Already I've spent 12,000/- regarding this issue.Now i'm bit confused and seeking some advice on 'what to do' ? 1 Quote Link to comment Share on other sites More sharing options...
aps Posted June 3, 2015 Share Posted June 3, 2015 On 6/3/2015 at 5:29 AM, gsumithm said: Need help from experts & owners who experienced same situation before.My car is Kia Rio(2003 model) Continuous rattling noise came from engine bay from compressor and it was compressor clutch plate. As suggested by A/C technician I replaced, 1.Compressor clutch plate 2.Pulley assembly 3.Bearing 4.A/C hose (since there was a leak-confirmed by dye test) 5.Filled gas Now I've noticed that the AC will no longer blow cold air if I've been idling too long (either parked, sitting in traffic, at a long traffic light, etc.) Once I start driving again, it cools back down like normal. Now technician is suggesting me to replace compressor which will cost me 17,500/- (reconditioned), 34,000/- (brand new) Already I've spent 12,000/- regarding this issue. Now i'm bit confused and seeking some advice on 'what to do' ? there is a system to increase RPM of ur engine when A/C on while idling, you need to check that no need to change ur compressor if it give good cool air when u driving i'll PM my A/C techs phone number call him (he only replace wht is necessary if not repairable) btw recon A/C comp only cost bet 6500-10,000/- in Susmitha @ Nawala Quote Link to comment Share on other sites More sharing options...
wolseley Posted June 3, 2015 Share Posted June 3, 2015 If the clutch and idle-up switch working properly,the reason may be that your compressor is unable to give enough compression at low RPM. If so no remedy other than replacing. Quote Link to comment Share on other sites More sharing options...
MV-5 Posted June 3, 2015 Share Posted June 3, 2015 once you reproduced this problem, if you rev up the engine (say 2.5K RPM,but vehicle is standstill) , then AC works fine?. If the answer is YES, probably your technician is right. If the answer is NO, that means AC is working fine when the vehicle is moving only. that means AC condenser or it functionality (ex:Fan) doesn't work properly 1 Quote Link to comment Share on other sites More sharing options...
gsumithm Posted June 3, 2015 Author Share Posted June 3, 2015 On 6/3/2015 at 5:47 AM, aps said: there is a system to increase RPM of ur engine when A/C on while idling, you need to check that no need to change ur compressor if it give good cool air when u drivingi'll PM my A/C techs phone number call him (he only replace wht is necessary if not repairable) btw recon A/C comp only cost bet 6500-10,000/- in Susmitha @ Nawala @aps RPM is around 700-850 at idle while a/c is on (i think it's normal). btw i chkd sasmitha thy quoted 19,500/- for Korean compressor.17,500/- at Aj*nt*a m*tors On 6/3/2015 at 7:55 AM, MV-5 said: once you reproduced this problem, if you rev up the engine (say 2.5K RPM,but vehicle is standstill) , then AC works fine?.If the answer is YES, probably your technician is right. If the answer is NO, that means AC is working fine when the vehicle is moving only. that means AC condenser or it functionality (ex:Fan) doesn't work properly @MV-5 ya,if i accelerate to 1500-2000 rpm while vehicle is standstill, as u said,again a/c blowing cold air Quote Link to comment Share on other sites More sharing options...
gsumithm Posted June 3, 2015 Author Share Posted June 3, 2015 On 6/3/2015 at 7:19 AM, wolseley said: If the clutch and idle-up switch working properly,the reason may be that your compressor is unable to give enough compression at low RPM. If so no remedy other than replacing. as i mentioned earlier,cluth was replaced recently due to dis a/c issue. i hav no idea abt idle-up switch. my a/c technician also said "compressor culdn't compress/giv enough compression at idle" as u mentioned Quote Link to comment Share on other sites More sharing options...
The Don Posted June 3, 2015 Share Posted June 3, 2015 The issue here is quite simple. The compressor is not producing enough compression at idle rpm. This could be because of low gas or a fault with the compressor. To check this you need to attach a pressure gauge to the AC circuit and check compression at idle and then revved up and it will become obvious. Quote Link to comment Share on other sites More sharing options...
Saturn Posted June 12, 2015 Share Posted June 12, 2015 700 rpm may be too low for aC. Is the ac idle up working? Does engine rpm increase or decrease when ac compressor kicks in? Quote Link to comment Share on other sites More sharing options...
Magnum Posted June 12, 2015 Share Posted June 12, 2015 I had the same problem in my Bluebird, it was solved once I replaced the compressor Quote Link to comment Share on other sites More sharing options...
gsumithm Posted June 12, 2015 Author Share Posted June 12, 2015 On 6/12/2015 at 4:25 AM, Saturn said: 700 rpm may be too low for aC. Is the ac idle up working? Does engine rpm increase or decrease when ac compressor kicks in? RPM goes up when A/C switched on. i'm not aware of ac idle-up switch Quote Link to comment Share on other sites More sharing options...
gsumithm Posted June 12, 2015 Author Share Posted June 12, 2015 (edited) finally i replaced with a used Korean compressor.done full service.replcd condensor filter.now a/c working fine at idle and at normal drive.but i felt 'cool' is not enough (around 12-3 pm othrwise ok) and rechkd wid technician,but he said pressure at idle (230-250) and at 2000 rpm (320) is ok.he replied dat cooling issue is may b due to "hot weather" Edited June 12, 2015 by gsumithm Quote Link to comment Share on other sites More sharing options...
aps Posted June 12, 2015 Share Posted June 12, 2015 On 6/12/2015 at 11:09 AM, gsumithm said: finally i replaced with a used Korean compressor.done full service.replcd condensor filter.now a/c working fine at idle and at normal drive. but i felt 'cool' is not enough (around 12-3 pm othrwise ok) and rechkd wid technician,but he said pressure at idle (230-250) and at 2000 rpm (320) is ok. he replied dat cooling issue is may b due to "hot weather" can you adjust temp of ur A/C ? Quote Link to comment Share on other sites More sharing options...
Crosswind Posted June 12, 2015 Share Posted June 12, 2015 (edited) On 6/12/2015 at 11:09 AM, gsumithm said: finally i replaced with a used Korean compressor.done full service.replcd condensor filter.now a/c working fine at idle and at normal drive. but i felt 'cool' is not enough (around 12-3 pm othrwise ok) and rechkd wid technician,but he said pressure at idle (230-250) and at 2000 rpm (320) is ok. he replied dat cooling issue is may b due to "hot weather" Sounds pretty much like the reply you would get from a typical A/C workshop in Ethulkotte area What's a condensor filter by the way? I don't think he fixed the right compressor for your car. Edited June 12, 2015 by Crosswind Quote Link to comment Share on other sites More sharing options...
The Don Posted June 15, 2015 Share Posted June 15, 2015 On 6/12/2015 at 11:09 AM, gsumithm said: finally i replaced with a used Korean compressor.done full service.replcd condensor filter.now a/c working fine at idle and at normal drive. but i felt 'cool' is not enough (around 12-3 pm othrwise ok) and rechkd wid technician,but he said pressure at idle (230-250) and at 2000 rpm (320) is ok. he replied dat cooling issue is may b due to "hot weather" This is a typical problem in SL. This issue is either the condenser is not doing a good enough job cooling, the compressor is not compressing enough or the expansion valve on the evaporator is faulty. Does the situation improve is you spray water on the condenser? Check the condenser fan, another usual culprit. Also check the pressure cut off. Quote Link to comment Share on other sites More sharing options...
Twin Turbo Posted January 30, 2016 Share Posted January 30, 2016 (edited) Your prob seems to be partially resolved, one more thing, have you looked at your cooling system? as a "hot" running engine will not properly cool the condenser as the rad is next to it.Also make sure both cooling fans work with the compressor. so as a precaution , replace the thermostat valve+rad cap and add fresh coolant as if no maintenance has been done to your car's cooling system before it blows up and empties your wallet. I've seen recon Hyundai Accent's having smaller radiators than the brand new models of the same age/model .As Hyundai Own Kia you may have the same prob, Yes the time you mentioned is the hottest in Col and gives the hardest workout for your a/c., overfilling of refrigerant is a common mistake our a/c mechs make,we must take into account that your car is more than ten years old and make sufficient adjustments for the age/mileage. if you drive an auto get the idle speed checked as when you engage D , there is a significant drop in RpmLastly,do a good clean up of the condenser and give it a gentle wash . you'll be amazed with the results. And increase A/c idle up to approx 900 Rpm it will cause less load on everything, Edited February 2, 2016 by Twin Turbo 1 Quote Link to comment Share on other sites More sharing options...
Twin Turbo Posted January 30, 2016 Share Posted January 30, 2016 (edited) On 1/30/2016 at 5:30 AM, Twin Turbo said: once your good and chilly, recommend http://forum.autolanka.com/topic/17275-front-windshield-tint/#entry283786 Edited January 31, 2016 by Twin Turbo Quote Link to comment Share on other sites More sharing options...
