Dear experts,
I owned a Honda city 2001 (mileage 091242). I was using this for last 5 years and I always use Mobil 15W-40 and oil change done in between 6 to 9 months period.
I am wondering what is the actual mileage I can run after a oil change with Mobil 15W-40?
Thank you
7 answers to this question
Dear experts,
Thank you
You are probably going to get different answers but what I would do is:
1. If this oil is non-synthetic and if its Mobil Delvac 1300 Super 15W-40 I would run it for 5000km or THREE MONTHS, whatever comes first (if this is some other SYNTHETIC Mobil 15w-40 then 5000km or SIX MONTHS, which ever comes first).
2. I'm no expert, but based on your usage and service habits as mentioned I would only use a synthetic diesel oil
Edited by Kavvz
it is very simple. check the API Service Category of your engine oil, when you buy oil don't see about the Brand name see only about the API Service Category and Viscosity index.
if your engine oil API Service Category is
CJ - can run 10,000km or six months
CI - can run 5,000km or six months
CH - can run 5,000km or six months
CF- can run 3,000km or Six month
http://www.oilspecifications.org/api_eolcs.php
10W40 is the viscosity. did you check the API Service Category?
Edited by Nilantha
I'd be interested to see where you got those figures Nilantha as they don't tally with common guidelines nor with my manufacturer's guidelines. (The posted link doesn't provide the information as listed)
Edited by Kavvz
CJ- Fully Synthetic
CI - Synthetic blend ++
CH - Synthetic Blend +
CF - Mineral Oil
so you check how many miles can run using Mineral oil and how many can Synthetic oil.
but other thing is if you use normal Diesel it is better use CF grade oil and change every 3000km Because CF Grade designed to use with high sulfur fuel
or CH4 can use with normal Diesel and can change 5000km
Edited by Nilantha
