Hi Autolankans,
I use a Toyota Passo (2004 model) and there is a small button near gear shifter, OverDrive.
Can someone explain the usage of this button?.. In normal traffic dirve should we turn OFF/ON?.. In highway should we turn OFF/ON?..
Regards,
Overdrive is the 4th Gear
its better to leave it on all the time,
The only place i could think of using the OD is when going up or down a hill.
*Up a hill to limit the hunting of gears (depend on how you accelerate)
*and down a hill to give a bit of engine breaking.
  • Like 3
The Hiace has D3 instead of O/D and it makes a major difference when going downhill, plus on a 2 tonne vehicle like the Hiace its not a good idea go down a hill with all the strain put on the breaks
Hmm better to Turn OD on normal conditions?. Like driving in colombo?..
Yes i keep O/D on during normal driving or else it puts an extra strain on the gearbox
Yeap O/D off means There will be more gear changes, and that means more efficent and a smoother ride
Edited by Schiffer
O/D on means more gear changes :P
with O/D off the last gear is unavailable :D
Basically O/D means the final gear.. Leaving O/D on in traffic makes no difference.. But when you are driving 50+ kmph where you can use the last gear., keep O/D on so the gearbox can use the final gear.. O/D allows your vehicle to operate at a lower rpm at higher speeds and it gives you better fuel economy and quieter ride..
oh yea i meant OD on
That's what usually "B" does in CVTs.
AFAIK it is for the "Engine Braking".. It adds more drag when decelerating..
plus i havent come across a place in colombo to swith the OD off still.
U mean OD on ryt?
U mean OD on ryt?
nope off,
like i said earlier, you would need it when cruising down a steap hill or going up a very steap hill
i havent encounter yet a place in colombo like so.
in kandy and nurawaeliya, yes
Let me make this simple
when O/D is deactivate/off light comes on the instrument cluster , when O/D is active/on light on the instrument cluster stays off
You keep O/D on(light off) during normal driving
you turn O/D off(light comes on) when going downhill if needed when going up hill as well or when towing
If you are speeding on a flat road with O/D off its gonna put a strain on the gearbox
Does O/D off really give engine braking? I thought that's only on L and 2 whie O/D off simply stops shifting to the last gear. Correct me if I'm mistaken.
it does but at some speed
Im not sure how it is on a car, but on my Hiace it makes quite a difference. Once while going down Kadugannawa I had it in D3 and shifted to D4 to see the difference, it felt like as if I lost the brakes all of a sudden
Thanks for the clarifications.. By the way is there any SIGNIFICANT impact on fuel consumption? :)
Yes, since the top gear cannot be reached the engine revs more which means more fuel is burned.
I do not personally blame you. But you (most of new car owners) will do anything -even harmful-to your vehicle to save fuel. Thanks to new EFI systems you can't change fuel mixtures. Otherwise all vehicles will end up with burnt rings and pistons.
new car owner?.. :sad-smiley-067: :sad-smiley-067: :sad-smiley-067:
Not meant personally you!!! BUT YES!!! LOT OF NEW CAR OWNERS....(whom may have been upgraded from their Indian dara messa type motor bike or tuk-tuk. They will do anything to save a drop of fuel.
This is my first vehicle and what I can buy from my salary level.. For the record, costs me around 20,000 per month only for fuel.. :speechless-smiley-004: :speechless-smiley-004: :speechless-smiley-004:
tbh i dont see anything wrong with that.
Not everyone buys a car for plesure. some just wants a comfortable way to travel from A - B and it to be economical.
Could have been worse, could have gone to a Indian peice of shit.
For some people who travel a lot, fuel economy is a must. and 20000 on fuel?
Are you taking Trips to the Moon?
