Hi Guys,
I recently purchased a Toyota Premio 2002 model and I'm having some issues with the power shutters.
The drivers side works fine but the other 3 don't work properly...they don't work from the main control but sometimes they work individually but the thing is once the mirror goes down it doesn't come back up.
I took it to a garage & they said all switches including the main controller needs to be replaced.
Can the switches be repaired? or if i need to replace where can i get for my model?
Any help highly appreciated.
adilisme
usually the switches on the doors other than driver side has little use.
This might lead to oxide build up on the connectors.
Remove them clean and apply WD40 or ABRO contact cleaner.
  • 3 weeks later...
Hi Guys,
I just checked with T****A Lanka & they said it'll cost me close to 150K to replace all 4 switches.
I'm still convinced that the switches can be repaired so therefore if you guys can recommend to me a really good car electrical pro who will be familiar with my issue that would be highly appreciated.
Regards,
adilisme
Hi Guys,
adilisme
Look it up on eBay mate, i'm sure the switches were shared in many toyotas
Are you sure it is the switches giving you trouble not sticky window channels? Do the windows get stuck halfway after moving in one direction for a while? If so it could be due to dirt inside or misalignment of the channels. Try cleaning the channels with a piece of cloth soaked in dashboard shine or tire shine (that's what I use) wrapped around a wooden spatula (like a Popsicle stick) after fully opening the windows. If it improves the situation you may use a silicone spray lubricant on window channels as a lasting solution.
Hi Guys,
Thanks for all the advice...issue now sorted...the switches had to be replaced...made a big mistake by going to Pala Auto Electricals...Needed to replace my head light bulb also...They quoted 5000/- for one switch and i had to replace 3...In the end 2000/- for light bulb plus replaced one switch all came to 10,000/-...My bro said since we're close to some spare part shops lets just check it out...Found a small spare shop he gave me 2 switches plus the casings for all 4 which were damaged all for 8,000/- and he said a head light bulb price is only 650/-...he completed the job in 15 mins also...felt like kicking myself...anyways lesson learnt i guess.
  • 5 weeks later...
Hi Guys,
Can you please PM me the details of that mechanic/spare shop. im also having same problem with my passenger side window switches. they are blinking and not working..
