Davy Posted November 10, 2018 Posted November 10, 2018 1 hour ago, EvooSpeed said: did you need to cut any of the metals inside the dash to make the cables reach properly to its new relocate area? No. The cables just need to be re-routed to the new location. Quote
EvooSpeed Posted November 10, 2018 Posted November 10, 2018 did they arrived properly i mean too tight or ok ? beacuse since our ac controls are mechanical if it is tighter than original for example the cold and hot will not turn to full cold or full hot Quote
Davy Posted November 25, 2018 Posted November 25, 2018 On 11/10/2018 at 10:33 PM, EvooSpeed said: did they arrived properly i mean too tight or ok ? beacuse since our ac controls are mechanical if it is tighter than original for example the cold and hot will not turn to full cold or full hot The cables are not pulled from their anchor points, so the regulators feel the same after the conversion. Quote
