Mitsubishi Lancer Cs1 2003
Kmadhuranga
Hello,
I have mitsubishi lancer cs1 2003 1.3cc. Thing is few weeks back i realized some time my car is automatically accelerating. i went to D*MO and that guys done clean up throttle and now is ok, they said O ring has to be replaced and i try to find one, How can i find the Part number so i can buy online. is there any way to find that part number without visiting Unit#d Mot#rs?
  On 12/28/2015 at 3:29 AM, Kmadhuranga said:
Hello,
First time I heard of a Mitsubishi being taken to D!MO but okay...
There are many O rings on the engine, can you be more specific as to which O ring you are referring to? Injector O rings? If yes, they're pretty easy to source locally and should be pretty cheap.
At ASNU, whenever they do an injector cleanup, they always replace the injector O rings whether or not its damaged. they have stocks there itself though.. I'm wondering how come they have O rings that match all the vehicle injectors..
Hello,
Try to follow the link https://www.amayama.com/en/genuine-catalogs/mitsubishi and enter the chassis number. If your model is in their catalogs you should be able to trace whatever the o-ring you are looking for.
Injectors for different vehicle makes are produced by specialized OEM part suppliers like NipponDenso and Bosch. So the o-rings are common for vehicles using the same injector.
  • Like 3
