I got a serious battery issue with my iPhone 5S. This is now almost 3 years old. Since few months battery was draining very fast even during standby time. Few times I diagnosed this from shops and all said there is nothing wrong. But there is something wrong and software updates did not fix it. Currently it is on iOS 8.1.1 and I cannot update to latest iOS because the phone has very limited memory available, most probably it will not fix this issue (as usual) and anyway I don't want those fancy upgraded features.
Now got a new problem - a real headache. When battery level is reducing around 45% (sometimes even around 59%) it shuts down suddenly. It doesn't show the usual battery low warnings. When it is plugged and restarts automatically for charging, battery level is displayed around that percentage (around 45%).
I searched on the Internet and went thru few articles and forums including Apple discussion forums. There are 2 options.
Option 1: Do a Device Firmware Upgrade (DFU) that may solve software and firmware problems (a painful, time consuming process and there is a risk in this). Even after a successful DFU upgrade problem may not be solved and if so you need to go to option 2.
Option 2: Simply replace the battery from a shop that will cost some 7,000 - 8,000 rupees I think. Most probably this will fix the problem.
If any of you have experience in similar problem/ battery issue with iPhone please let me know how did you fix it/ what do you recommend from above 2 options.
Cheers!
1 hour ago, Quiet said:
iphone - vehicles? :huh:
it's the lounge so yes.
Edited by matroska
  • 3 weeks later...
Update:
I went to a repair shop in front of Savoy Wellawatta. They checked the phone and said there is a power short and battery replacement may not solve the problem. Anyway they will not simply replace the batteries if there is a short. To fix the power short problem it may take few days.
