madushan.a Posted August 12, 2016 Posted August 12, 2016 Hi, I got a serious battery issue with my iPhone 5S. This is now almost 3 years old. Since few months battery was draining very fast even during standby time. Few times I diagnosed this from shops and all said there is nothing wrong. But there is something wrong and software updates did not fix it. Currently it is on iOS 8.1.1 and I cannot update to latest iOS because the phone has very limited memory available, most probably it will not fix this issue (as usual) and anyway I don't want those fancy upgraded features. Now got a new problem - a real headache. When battery level is reducing around 45% (sometimes even around 59%) it shuts down suddenly. It doesn't show the usual battery low warnings. When it is plugged and restarts automatically for charging, battery level is displayed around that percentage (around 45%). I searched on the Internet and went thru few articles and forums including Apple discussion forums. There are 2 options. Option 1: Do a Device Firmware Upgrade (DFU) that may solve software and firmware problems (a painful, time consuming process and there is a risk in this). Even after a successful DFU upgrade problem may not be solved and if so you need to go to option 2. Option 2: Simply replace the battery from a shop that will cost some 7,000 - 8,000 rupees I think. Most probably this will fix the problem. If any of you have experience in similar problem/ battery issue with iPhone please let me know how did you fix it/ what do you recommend from above 2 options. Cheers! Quote
madushan.a Posted August 12, 2016 Author Posted August 12, 2016 21 minutes ago, Quiet said: iphone - vehicles? No restrictions I think.... Forum under Home > Other > ..... Quote
matroska Posted August 12, 2016 Posted August 12, 2016 (edited) 1 hour ago, Quiet said: iphone - vehicles? it's the lounge so yes. Edited August 12, 2016 by matroska Quote
Muditha420 Posted August 12, 2016 Posted August 12, 2016 IF you do want to cut down on the cost etc... i recommend doing it by yourself. depends on how competent you are. on replacing the battery you can refer this <https://www.ifixit.com/Guide/iPhone+5+Battery+Replacement/10587> and also if you can pop into eBay you can get a battery plus tools to do what you need Quote
pug306xsi Posted August 12, 2016 Posted August 12, 2016 clear your phone and update to 9.3.4 and see if you still have issue before going to replace the battery. Quote
madushan.a Posted September 2, 2016 Author Posted September 2, 2016 Update: I went to a repair shop in front of Savoy Wellawatta. They checked the phone and said there is a power short and battery replacement may not solve the problem. Anyway they will not simply replace the batteries if there is a short. To fix the power short problem it may take few days. Quote
