Hi Guys
Need some suggestions/tips on buying a budget friendly 4x4.
I have searched the vehicle market and only budget friendly jeep seems to be Mahindra Bolero. but mostly its 2wd version and rarely you find a 4x4.
few questions i need help on
1. 4x4 conversion possible for bolero single cab and cost?
2. Upgrading tyre size and suspension?
3. is this conversion and modification really worth it?
4. Even a engine swap?Japanese engine
Would really appreciate some suggestions and thoughts....
Pshan
Seriously, you should consider a very old Toyota, Mitsubishi or a Nissan. It will last much much longer than a brand new Bolero. I've known a company in Colpetty (close to the sea), which had a fleet of Boleros with them. It took just 3 years for them to start rusting. Even if you keep a Japanese vehicle right on the beach, it will take much longer to start rusting.
As others have mentioned, your money would be better spent on an older Jap than a Bolero.
If you're looking for a cheap rig that you can take offroad, I've heard that the Suzuki Jimny is surprisingly capable. I have also seen some CJ and TJ Wranglers advertised for not a lot of money. And most of them are running Mitsubishi engines now so you can cross the engine swap off your list and focus on Suspension and Tyres.
Hello Shan_86
I think Mazda BT50 single cab is a better solution and one of my mate hook up with a one for 1.8M 6 months back, been a PB number you don't need special licen to drive.
Bolero - you can't do safari on that mate, Animal scared of the engine noise. lol
Suzuki Jimny is a beast only issue if you get stuck you are really stuck with 1.3 motor.
Good Luck
JC
