omee Posted January 22, 2017 Posted January 22, 2017 (edited) Anybody has an idea about clutch kit Prices and good reasonable places to buy????? Vehicle is Suzuki Liana Japan 2004. Suddenly got a burning smell and when the heat comes clutch doesn't works when cruising on a traffic. Have to stop and wait 15 minutes for a cool down and then it works back... I think I have to replace 'em clutch kit or any idea whats going on around me according to above mentioned prob????? Edited January 22, 2017 by omee Quote
Davy Posted January 22, 2017 Posted January 22, 2017 Was a brake or clutch repair done recently? Does your car accelerate normally when the engine is cold? You can search the forum/internet to find methods of checking for a possible worn out clutch, yourself, without taking apart anything. Example. If the above test doesn't reveal anything, I think you first need to bleed the system out to see if the problem was due to air trapped in the system, causing the clutch to slip. When this happened, did it feel like the car struggled to accelerate? Quote
