I observed that my car(Suzuki Swift 2010) dashboard lights flickering when turn on the AC. Also heat meter goes to danger(red) level when it turn on.
Also that flickering comes when the fuel level go down to the "E" level. Seems like when some indicator light is turn On (when AC is turn on or fuel level) in dashboard these flickering occurs.
Where should we need to check?
p.s : I'm rarely using the car. Last time I drove it after 3 weeks.
+1 for checking radiator fans while AC is on.
For the flickering lights, get your battery and charging system checked out. Also make sure your drive belt is not loose and slipping.
  • 3 weeks later...
1 hour ago, flashmark said:
Thank you for your assistance. After cleaning the battery terminal, that issue got disappeared :)
Cheers,
Glad to be of assistance.
TT.:)
