  • โ€‹ Welcome Forum Guest! ๐Ÿ‘‹ โ€‹
16 hours ago, Prangi said:
Hi,ย
I need a help on this ERC
00998a9c00000000
1
F298808B
7 hours ago, Isuruka said:
Please help.
My ERCย 00642c1200000000
model - NSCP W64
F2632201
  • Thanks 1
  • 3 weeks later...
10 minutes ago, Pushpitha_mandara said:
Checked again and menu seems disabled, does this mean it worked?
If it worked you should be able to access the stereo (CD/USB playing etc)
And reversing camera should function if it didn't up until now
Tried again and menu was enabled this time and it gave a message as ERC wrong. Below is the image of ERC.
Well, the code you previously sent is right; so the passcode should be D 4 C E E B 7 2.
Either you're entering it wrong or your player uses a unique algorithm to encode the ERC. ? Maybe you entered 8 instead of B?
Entered the same but no luck :( most probably encoding is different. Any way thank you for the help!
Don't tell me Toyota has wised up and has changed the ERC encoding :( You're sure you pressed on the OK button (One on the right - watch the video) after entering the code right?
I did and used the Google translater as well to make sure correct buttons. And message was also specific saying code is wrong :(
  • Sad 1
They've indeed changed the encoding of the newer players; it seems even paid services are unable to decode those-
Dear Sir,
I Would appreciate if you could help me to unlock. The following is my car info:
Vehicle Name: Toyota Wish
Navigation System Name and Model: NSDT - W59
16 digits ERC serial number: 1G30127512345678
Thank you!
2 hours ago, yip said:
Dear Sir,
Thank you!
As long as the 2nd letter is "G", it's not decodable
You can try inserting a wrong code (like 12345678)/Disconnect the battery, wait 10 mins and see if changes on the next start - if it does you're in luck -ย  if it doesn't then... ?
Edited by Hyaenidae
  • 3 weeks later...
