I have been using a Honda FIT GE6 2009 Petrol Car for several years now and its almost 94,000 Kms on the odometer.
Few months back car starts to knock (unsure this is the right term to describe the issue) starting at 1500 and goes away if I push the accelerator down or up a bit. If I keep the paddle in 1500 RPM the knock keeps continuing. Most of the time it starts knocking 1500 RPM and around 40Km/h but on highway or freeways happens on 70-80Km/h. Also this is quite noticeable as its shaken the whole car.
This issue starts only after engine is getting hot. When I starts the car in the morning it runs very smooth but after driving around 10-15 minutes above symptoms starts. And also after a long trip like 4-5 hours of continuous driving car really hesitates to drive up hill. If I push the accelerator down, engine starts rev up without moving forward and after 2-3 seconds it starts moving smoothly.
First thought this is a gearbox issue and changed CVT as well as added CVT conditioner from BG. Nothing changed and then did a full engine tune up (cleaning complete fuel system including petrol pump). Finally cleaned and replaced the EGR valve with a reconditioned one but no luck so I fixed my original EGR back. No error codes or no CEL. Also the engine mounts are in good condition.
I have checked my plugs and injectors from two mechanics and both mentioned no need of changing them.
If you guys can please share your thoughts here, that would be really helpful.
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
Shalin
Edited by Shalin11 answers to this question
