Ted Posted April 12, 2018 Posted April 12, 2018 Hi guys, I recently did an auto transmission fluid change. When I checked the level early in the morning the fluid level shows around 1 cm above HOT upper cut level. I mean there are HOT upper and lower cut within which the lvel should be when hot and COLD upper and lower within which fluid lvel when cold. 1) Is there excess amount of oil? 2) Do I need to drain ? 3) My auto is working well but it gets a lil bit delay to chang into gears ( I dunno weather it is a normal thing because I am always expecting no time interval between any two gear ). Might this because of this excess fluid? Quote
Twin Turbo Posted April 12, 2018 Posted April 12, 2018 (edited) Was the engine running at idle? on 'P' ? Edited April 12, 2018 by Twin Turbo Quote
Ted Posted April 12, 2018 Author Posted April 12, 2018 Nop.. It was early morning in cold state. I mean not running. After I post this, I had a run around 40 mins and checked engine off after that on parking. Same level ( 1 cm above upper HOT line) no change. Quote
john cooper Posted April 12, 2018 Posted April 12, 2018 Hello Ted My gut feeling this won't blow any seals in your tranny, but i would go back to the place the oil change done and get them to remove the oil. Ask them to remove and give it back to you as you may need to top up the oil regards, JC Quote
