amsandun Posted May 2, 2018 Share Posted May 2, 2018 Hi everyone, After some time of finding facts, I got my first car (Toyota Vitz 2016/10). Personally imported. It has 12500 km on the odometer. So I thought of getting a service done before put it on the road. Since I am new to cars and stuff, can someone please let me know what to specially look for and replace in the first service. I was told that engine oil has to be changed. What about oil filter, air filter etc...? Thanks... Quote Link to comment Share on other sites More sharing options...
kush Posted May 2, 2018 Share Posted May 2, 2018 Change Engine oil and filter. Check air filter Check brake fluid, pads, transmission oil, wheel alignment 1 Quote Link to comment Share on other sites More sharing options...
iRage Posted May 2, 2018 Share Posted May 2, 2018 What kush said...also fyi...in Japan the brake fluid and coolant gets changed every two years during the shaken inspection. So that is not found in the JDM service schedules....but typically brake fluid is to be swapped every 20,000km or every two years; which ever comes first. 1 Quote Link to comment Share on other sites More sharing options...
Hyaenidae Posted May 2, 2018 Share Posted May 2, 2018 (edited) On 5/2/2018 at 9:53 AM, iRage said: What kush said...also fyi...in Japan the brake fluid and coolant gets changed every two years during the shaken inspection. So that is not found in the JDM service schedules....but typically brake fluid is to be swapped every 20,000km or every two years; which ever comes first. Expand Service schedule issued by the Manufacturer for my car (Lancer export version) recommends changing coolant every 100,000km or 5 years (Factory filled coolant is to be replaced after 160,000km or 8 years! why is that?) and Brake fluid every 40,000km or 2 years Edited May 2, 2018 by Hyaenidae Quote Link to comment Share on other sites More sharing options...
iRage Posted May 2, 2018 Share Posted May 2, 2018 On 5/2/2018 at 10:12 AM, Hyaenidae said: Service schedule issued by the Manufacturer for my car (Lancer export version) recommends changing coolant every 100,000km or 5 years (Factory filled coolant is to be replaced after 160,000km or 8 years! why is that?) and Brake fluid every 40,000km or 2 years Expand No idea...could be the type of coolant used and environmental conditions it goes through ? In Japan they are not even listed in the manufacturers schedule because it is mandatory done at the shaken inspection. Actually the coolant might be every three years; I am not sure....but the brake fluid is every 2 years or 20,000km Quote Link to comment Share on other sites More sharing options...
amsandun Posted May 2, 2018 Author Share Posted May 2, 2018 On 5/2/2018 at 9:25 AM, kush said: Change Engine oil and filter Expand Thank you all for the replies.What type of engine oil should be used? is Mobil the one widely used and the good one? Any specific grade to chose from them? Quote Link to comment Share on other sites More sharing options...
Hyaenidae Posted May 2, 2018 Share Posted May 2, 2018 On 5/2/2018 at 3:13 PM, amsandun said: Thank you all for the replies.What type of engine oil should be used? is Mobil the one widely used and the good one? Any specific grade to chose from them? Expand I've used Mobil and Valvoline, never had a problem with either of the brands Use SAE 5W30, API SN / ILSAC GF If you choose a mineral oil the OCI is 6 months / 5000kms (whichever comes first) If you choose a full synthetic oil OCI is 12 months / 10000kms (whichever comes first) 1 Quote Link to comment Share on other sites More sharing options...
amsandun Posted May 11, 2018 Author Share Posted May 11, 2018 On 5/2/2018 at 3:24 PM, Hyaenidae said: I've used Mobil and Valvoline, never had a problem with either of the brands Use SAE 5W30, API SN / ILSAC GF If you choose a mineral oil the OCI is 6 months / 5000kms (whichever comes first) If you choose a full synthetic oil OCI is 12 months / 10000kms (whichever comes first) Expand Is it a must or a good practice to use Toyota oil for Toyota vehicles? Does it matter which oil we put in? Quote Link to comment Share on other sites More sharing options...
Hyaenidae Posted May 11, 2018 Share Posted May 11, 2018 On 5/11/2018 at 7:34 AM, amsandun said: Is it a must or a good practice to use Toyota oil for Toyota vehicles? Does it matter which oil we put in? Expand No, it's not, the brand really doesn't matter, as long as it's the correct viscosity (5W30) and meets manufacturer's recommended API rating (API SN) it doesn't matter the brand of the oil you put in. Go for an oil which is listed on API website though, like Mobil/Valvoline - Toyota outsources their oil from a reputed manufacturer (Mobil?) too if I remember correctly. 1 Quote Link to comment Share on other sites More sharing options...
iRage Posted May 11, 2018 Share Posted May 11, 2018 On 5/11/2018 at 9:35 AM, Hyaenidae said: No, it's not, the brand really doesn't matter, as long as it's the correct viscosity (5W30) and meets manufacturer's recommended API rating (API SN) it doesn't matter the brand of the oil you put in. Go for an oil which is listed on API website though, like Mobil/Valvoline - Toyota outsources their oil from a reputed manufacturer (Mobil?) too if I remember correctly. Expand Depends on the market and the time period....they used to outsource it to Mobil in quite a few regions in the past but have phased away from Mobil in some markets. In Japan they outsource it to CASTLE. 1 Quote Link to comment Share on other sites More sharing options...
nagaya Posted May 12, 2018 Share Posted May 12, 2018 On 5/2/2018 at 10:12 AM, Hyaenidae said: Service schedule issued by the Manufacturer for my car (Lancer export version) recommends changing coolant every 100,000km or 5 years (Factory filled coolant is to be replaced after 160,000km or 8 years! why is that?) and Brake fluid every 40,000km or 2 years Expand My service manual says, Except 4A9, 6B3, 3B2 replace every 40000km or 2 years for coolant and for 4A9, 6B3, 3B2 engines replace first at 160,000km or 8 years, then every 100,000km or 5years, What is the engine of CY2? Isn't it a 4Gxx ? Break fluid, replace every 40000km or 2 years Engine oil, replace every 15000km or 1 year, although we are changing it every 5000km or 6 months here Quote Link to comment Share on other sites More sharing options...
Hyaenidae Posted May 12, 2018 Share Posted May 12, 2018 On 5/12/2018 at 4:28 PM, nagaya said: My service manual says, Except 4A9, 6B3, 3B2 replace every 40000km or 2 years for coolant and for 4A9, 6B3, 3B2 engines replace first at 160,000km or 8 years, then every 100,000km or 5years, What is the engine of CY2? Isn't it a 4Gxx ? Break fluid, replace every 40000km or 2 years Engine oil, replace every 15000km or 1 year, although we are changing it every 5000km or 6 months here Expand CY2 comes with a 4A91 / 4A92 engine And the manual says to change engine oil every 6mo/5k kms under severe conditions... 1 Quote Link to comment Share on other sites More sharing options...
nagaya Posted May 12, 2018 Share Posted May 12, 2018 On 5/12/2018 at 5:29 PM, Hyaenidae said: CY2 comes with a 4A91 / 4A92 engine And the manual says to change engine oil every 6mo/5k kms under severe conditions... Expand Thanks for the info I never knew it and though it is a 4G15 so both CY & CZ has different engines than Orion or Sirius Quote Link to comment Share on other sites More sharing options...
Hyaenidae Posted May 12, 2018 Share Posted May 12, 2018 On 5/12/2018 at 5:39 PM, nagaya said: Thanks for the info I never knew it and though it is a 4G15 so both CY & CZ has different engines than Orion or Sirius Expand Yup, CY series came with 4A91 engines (1500CC) till the end of 2011; from 2012 onwards it was 4A92 (1600CC) Quote Link to comment Share on other sites More sharing options...
