Sadik Posted May 21, 2018 Posted May 21, 2018 Guys, I feel that the current reverse cam in my Monty ( 2013 -4M41) , seems to have a rather narrow viewing angle to that of my previous X-trail. Monty was bought used and the reverse cam was installed by the previous owner which i think is a Chinese contraption coupled to a 5" viewing monitor mounted near the top right end of the WS. Can anyone suggest a branded reverse cam (with a wide viewing angle) , and also can there be a possibility of an incompatibility issue with the current generic monitor ? Quote
tiv Posted May 21, 2018 Posted May 21, 2018 (edited) Get a branded head unit, and a newer camera oem spec camera which fits in the reverse light or to the oem slot, for the right dimensions, not the local drill type, mount it in the oem slot, should be on the spare wheel trim, that gives you a fisheye look where u see the edge of the rear bumper, but not both the side margins. just the outer margin of the center fading away to the edge of the screen. Edited May 21, 2018 by tiv Quote
NRX Posted May 22, 2018 Posted May 22, 2018 Here is a budget option. I'm using it with my sedan and pretty happy with the viewing angles. 600L CCD HD 180 degree Fisheye Lens car camera Rear / Front view wide angle reversing backup camera night vision parking assisthttp://s.aliexpress.com/UzqqaINf?fromSns=Copy to clipboard Quote
JayZ Posted May 22, 2018 Posted May 22, 2018 This is the camera which i use on a 8 inch head unit screen. Looks way better than the OEM camera image which was displayed on the factory 5 inch screen. Also this has moving guide lines and wide view. https://www.aliexpress.com/item/Factory-supply-good-quality-170-Degree-Dynamic-trajectory-Rear-view-Camera-Best-day-and-night-vision/32729082164.html?spm=2114.10010108.1000023.14.9be87ee9Pcfe6Y 1 Quote
Sadik Posted May 22, 2018 Author Posted May 22, 2018 Thanks a lot JayZ , NRX & tiv Really appreciate your help on the matter 1 Quote
tiv Posted May 22, 2018 Posted May 22, 2018 7 hours ago, JayZ said: This is the camera which i use on a 8 inch head unit screen. Looks way better than the OEM camera image which was displayed on the factory 5 inch screen. Also this has moving guide lines and wide view. https://www.aliexpress.com/item/Factory-supply-good-quality-170-Degree-Dynamic-trajectory-Rear-view-Camera-Best-day-and-night-vision/32729082164.html?spm=2114.10010108.1000023.14.9be87ee9Pcfe6Y I am intrigued as to how the lines move as these vehicles do not have steering input and telemetry, is it accurate? does it shift as you steer or does it point to the vacant spot 1 Quote
JayZ Posted May 23, 2018 Posted May 23, 2018 No this does not have an input from OBD port to get steering angel. And not as accurate as the one with 360 systems with dynamic guide lines. It has some motion sensor LEDs and trajectory is calculated based on the vehicle movement. 1 1 Quote
Sadik Posted June 4, 2018 Author Posted June 4, 2018 Gentlemen, I went with Jay Z's suggestion & as on paper that looked the best solution of all at the right price. Any of you would care to recommend me a good place for an installation? Does Sun Lanka handle these kind of repairs where third party cam installations are involved? Quote
JayZ Posted June 4, 2018 Posted June 4, 2018 18 minutes ago, Sadik said: Gentlemen, I went with Jay Z's suggestion & as on paper that looked the best solution of all at the right price. Any of you would care to recommend me a good place for an installation? Does Sun Lanka handle these kind of repairs where third party cam installations are involved? In which area you are looking to get this installation done? I know a decent guy around Maharagama who does a good job in installing. He even has these High Res cams in stock. So you would save some time than getting through AliExp. Quote
Sadik Posted June 4, 2018 Author Posted June 4, 2018 Hi Jay Z, Maharagama is OK. Would you mind sharing his contact details. On a side note the cam was delivered last friday , a mere 6 day transit which i must say is quite fast for Aliexpress. Thanks a lot for the support Quote
JayZ Posted June 4, 2018 Posted June 4, 2018 2 hours ago, Sadik said: Hi Jay Z, Maharagama is OK. Would you mind sharing his contact details. On a side note the cam was delivered last friday , a mere 6 day transit which i must say is quite fast for Aliexpress. Thanks a lot for the support PM'd you the #. 1 Quote
