Dilshan Ravihara Posted May 21, 2018 Share Posted May 21, 2018 (edited) I want to know what is the oil we used for 4m40 (pajaro) differential I need quick answers for this .please be hurry Edited May 21, 2018 by Davy Corrected title and post grammar 1 Quote Link to comment Share on other sites More sharing options...
0 iRage Posted May 21, 2018 Share Posted May 21, 2018 On 5/21/2018 at 2:52 PM, Dilshan Ravihara said: I want to know what is the oil we used for 4m40 (pajaro)defernsel I need quick answers for this .please be hurry Expand Uhhh...4M40 is an engine....a differential is...uh....a differential ? The engine type typically has nothing to do with the type of differential oil that you need. Usually the differentials require SAE 90 API GL-5 oil for both and front and the transfer case requires SAE85 API GL-4. You better check with the other Pajero owners or even the agents to see what the recommended transfer case oil is. In some 4x4s the transfer case requires slightly thinner oil than the differentials. Not sure if it actually makes a difference in SL I hope you are plannign on replacing oil in both diffs and the transfer case. Quote Link to comment Share on other sites More sharing options...
0 Twin Turbo Posted May 21, 2018 Share Posted May 21, 2018 (edited) Since 99% of the driving is done on 2H,start with the rear diff. most pajero's of the V46 LWB have a LSD on the back. use SAE 140. You might also want to follow on a routene lubing of the front suspension/steering joints + front/rear propshaft 'u' joints. Cheers. Edited May 22, 2018 by Twin Turbo Quote Link to comment Share on other sites More sharing options...
Dilshan Ravihara
Edited by DavyCorrected title and post grammar
2 answers to this question
