Automatic gearbox for Suzuki Vitara 1997
2 answers to this question
On 11/13/2018 at 12:30 PM, Twin Turbo said:
Hi , and welcome to AL.,
Have you got a specialist to look at it ?
Hi @Twin Turbo
Thank you for your reply! Yes my mechanic had a look at it.
My 4wd broke down and my mechanic said all I needed was to replace the transfer case, which I helped him to procure. I found one at Automan in Koswatta, and brought it to him. But after fixing the transfer case, the mechanic tells me the transmission joint doesn't fit my old transmission joint pole. I need to find a transmission joint with a 'fatter glue' with 16 threads. My old joint pole has a 'thin glue' with 24 threads. I've been running all around trying to find one, but I didn't have any luck.
Do you have tips for me? I would really appreciate it more than anything. Thank you so much for your reply.
I have some pictures of my old joint pole and old transfer case. The new one is fitted inside the car so I couldn't take pictures of them.
