Chanaka Gunawardena Posted December 21, 2018 Share Posted December 21, 2018 (edited) Hi Experts, I'm using a honda civic ek3 for past 8 years. YOM 1996 and currently 214690 on the ODO (D15B EFI Engine / Manual) My problem is now when i accelerate beyond 2000 RPM and hold it in there (In Idle & Also while driving) check engine comes up. I don't notice any difference in drive or fuel consumption when this happens. Once I turn off the ignition check engine sign disappear. If I keep it under 2000 RPM check engine sign never show up. Funny thing is no one can find a OBD1 or OBD2 port on the car to scan it. So scanning the car is not possible. Today I have changed the TPS as instructed by my mechanic. But issue was still same. I haven't done a engine tuneup in a while but since there is no problem with fuel efficiency & engine performance i don't think it's necessary. (Correct me if i'm wrong) Fuel filter haven't been changed for the entire time. Services are done on correct mileage and recent one done on last week. Did the emission test last week and no problems in that report. Can someone help me to figure out what's going on with my car ? Thanks in advance ! Edited December 21, 2018 by Chanaka Gunawardena Quote Link to comment Share on other sites More sharing options...
Twin Turbo Posted December 21, 2018 Share Posted December 21, 2018 Check the engine oil level. Quote Link to comment Share on other sites More sharing options...
Chanaka Gunawardena Posted December 22, 2018 Author Share Posted December 22, 2018 (edited) On 12/21/2018 at 9:23 PM, Twin Turbo said: Check the engine oil level. Expand I did check it and it's up to the correct level on the dipstick Edited December 22, 2018 by Chanaka Gunawardena Quote Link to comment Share on other sites More sharing options...
PerfMad Posted December 24, 2018 Share Posted December 24, 2018 On 12/21/2018 at 1:19 PM, Chanaka Gunawardena said: Hi Experts, I'm using a honda civic ek3 for past 8 years. YOM 1996 and currently 214690 on the ODO (D15B EFI Engine / Manual) My problem is now when i accelerate beyond 2000 RPM and hold it in there (In Idle & Also while driving) check engine comes up. I don't notice any difference in drive or fuel consumption when this happens. Once I turn off the ignition check engine sign disappear. If I keep it under 2000 RPM check engine sign never show up. Funny thing is no one can find a OBD1 or OBD2 port on the car to scan it. So scanning the car is not possible. Today I have changed the TPS as instructed by my mechanic. But issue was still same. I haven't done a engine tuneup in a while but since there is no problem with fuel efficiency & engine performance i don't think it's necessary. (Correct me if i'm wrong) Fuel filter haven't been changed for the entire time. Services are done on correct mileage and recent one done on last week. Did the emission test last week and no problems in that report. Can someone help me to figure out what's going on with my car ? Thanks in advance ! Expand To start with, this car comes with a OBD1 port which is located under left dashboard. Port should look probably green colour or blue. Secondly, most of the garages have the bluetooth scanner. Go for a garage which has the cable scanner and those comes with a OBD1 adapter which can be connected to yours (as far as i know). Best thing is to get it scanned without replacing items blindly. Where do you live? If you are close by i can recommend a garage which has this scanner. Quote Link to comment Share on other sites More sharing options...
Chanaka Gunawardena Posted November 28, 2022 Author Share Posted November 28, 2022 (edited) Due to reduced performance, rough idle and random engine knocks I thought of doing an Engine tuning last weekend. My check engine issue was there all this time and I didn't try to fix it. Since the person who does the engine tuning good with identifying issues with the scanner, I asked him to have look. As @PerfMad explain to me, we found OBD1 green color 3 pin connector hidden near ECU in a cover on passenger side. (Mystery solved) I had 3 error codes related to MAP sensor & Both Knock Sensors. (Not sure the engine has 2 knock sensors) MAP sensor error went away after the cleaning and we checked it while driving and results looks normal (No sensor replacement required). It seems like both knock sensor wires were unplugged since no data can be read from the scanner. Found one located in the back of the engine just above the oil filter I have to take the car to a different mechanic to find and connect the wires first. I will update the thread once this is done. Edited November 28, 2022 by Chanaka Gunawardena 1 Quote Link to comment Share on other sites More sharing options...
