aruntantan Posted February 7, 2019 Posted February 7, 2019 Can someone recommend me a good shock absober testing place? One giving a report whether to replace. Also If they need replacement I'm hoping to buy from T**S, any other place you guys recommend? Car - Allion 260 1 Quote
alpha17 Posted February 9, 2019 Posted February 9, 2019 (edited) Take it to the To**ta La**a. They would do a test drive and tell. From my previous experience it's better to avoid the KYB (Sold by T**S), even it is made in Japan. After I replaced the all four shock absorbers of the 121, the car became extremely bumpy. I would never put KYB in any car again. Edited February 9, 2019 by alpha17 2 Quote
aruntantan Posted February 10, 2019 Author Posted February 10, 2019 Thanks for the replies, replaced shocks. Let me know if someone want to know the place. Quote
optimsh10 Posted February 10, 2019 Posted February 10, 2019 57 minutes ago, aruntantan said: Thanks for the replies, replaced shocks. Let me know if someone want to know the place. Please do share the Details and did you do a test first and get the results before replacing? Quote
aruntantan Posted February 10, 2019 Author Posted February 10, 2019 9 minutes ago, optimsh10 said: Please do share the Details and did you do a test first and get the results before replacing? Yeah, had a visual inspection, bump test, and finally had a test run, most of them are negative. then lift the car and removed the shocks, boy they look nasty. After the replacement, got a really smooth drive and improved on control (mostly cornering as well.) Back shock pair was ok, so didn't replace them. Not sure, its ok to publish the place here, send me a DM so I can guide you to them. By the way I replaced KYB shocks, there are 3 types of them, KYB Malaysian, KYB Klassic, KYB Japanase. I purchased the Japanese one around 26k for both. And it was around 32k for all other parts, boots etc. Malysian one was around 4 thousand less. 2 Quote
optimsh10 Posted February 10, 2019 Posted February 10, 2019 5 minutes ago, aruntantan said: Yeah, had a visual inspection, bump test, and finally had a test run, most of them are negative. then lift the car and removed the shocks, boy they look nasty. After the replacement, got a really smooth drive and improved on control (mostly cornering as well.) Back shock pair was ok, so didn't replace them. Not sure, its ok to publish the place here, send me a DM so I can guide you to them. By the way I replaced KYB shocks, there are 3 types of them, KYB Malaysian, KYB Klassic, KYB Japanase. I purchased the Japanese one around 26k for both. And it was around 32k for all other parts, boots etc. Malysian one was around 4 thousand less. Thanks for the Details .RS 32,000 for a pair of shocks seems reasonable. Would it be ok to replace only a single pair? if one pair is in good condition ? Quote
aruntantan Posted February 10, 2019 Author Posted February 10, 2019 2 minutes ago, optimsh10 said: Thanks for the Details .RS 32,000 for a pair of shocks seems reasonable. Would it be ok to replace only a single pair? if one pair is in good condition ? I've replaced front pair, and rear shocks was ok. Shocks are replaed in pairs. Quote
alpha17 Posted February 11, 2019 Posted February 11, 2019 @aruntantan How many kms have you done when you got the bad shock absorber signs? Are the new shocks KYB Excel-G? Quote
aruntantan Posted February 15, 2019 Author Posted February 15, 2019 On 2/11/2019 at 8:15 PM, alpha17 said: @aruntantan How many kms have you done when you got the bad shock absorber signs? Are the new shocks KYB Excel-G? 135,000 km on ODO. Was using the factory fitted one. It was the KYB Japanese one, not sure its Excel-G, will confirm, once I get back home, have the boxes with me. Planning to change the rear ones also, since they are also the factory fitted shocks. Quote
aruntantan Posted February 15, 2019 Author Posted February 15, 2019 @alpha17 yes its Excel-G. See the attachment. 1 Quote
alpha17 Posted February 15, 2019 Posted February 15, 2019 @aruntantan thanks for the information mate. I will also need to change the shock absorber in the near future. Quote
lamuyip Posted July 2, 2020 Posted July 2, 2020 @aruntantan, can you please share where did you test the vehicle. Quote
viraj_g Posted July 3, 2024 Posted July 3, 2024 (edited) Hi @aruntantan Can you pls share the place you got your old shock absorbers tested and the place you bought your new ones. Thanks Edited July 3, 2024 by viraj_g Quote
