ThilinaBa Posted May 4, 2019 Share Posted May 4, 2019 Hi guys, I've got an Alto 800 (2008). The driver side door of it needs to be slammed to lock properly. I could see that the door beading is a bit worn out which makes the slamming noice louder. I've tried lubricating the door latches / locks as well. Any idea of how to fix this problem at home? Appreciate if you can put some references to parts shops if need any. Thanks. Quote Link to comment Share on other sites More sharing options...
Twin Turbo Posted May 8, 2019 Share Posted May 8, 2019 Hi, Start by lubricating the door lock Quote Link to comment Share on other sites More sharing options...
Davy Posted May 8, 2019 Share Posted May 8, 2019 In addition to lubricating, you might also want to check if you can adjust the striker on the door jamb and look all round the door for a twisted rubber moulding/weather strip, or a rubber door cushion that's come off partially. Quote Link to comment Share on other sites More sharing options...
ThilinaBa Posted May 8, 2019 Author Share Posted May 8, 2019 @Twin Turbo : Already done that. No luck @Davy: The door beadings look a bit worn out on this particular door compared to others. Will try adjusting/replacing them. Quote Link to comment Share on other sites More sharing options...
