RaviJ Posted June 4, 2019 Share Posted June 4, 2019 (edited) I have a 1991 Nissan AD Y10. There is a knock(like misfire) when the engine is advancing. Every time I quickly push the throttle, engine knocks like it does not give response for a moment and then pulls. I tried replacing the carburetor and distributor. No luck with them. I suspect the issue is with the ECU which is fitted on the side right side to the gas paddle. I took the car to several garages and what I heard from them was, ECU does not play any role in connection with the ignition system of this car. I never have opened and checked the engine too. Can someone please help me with this. Anyone who experienced the same problem. Suggesting a good place to diagnose this would be a help too. Edited June 4, 2019 by RaviJ Missing some info Quote Link to comment Share on other sites More sharing options...
Twin Turbo Posted June 5, 2019 Share Posted June 5, 2019 Hi, before you take our car apart,.. re fill the fuel tank from a different fuel station,..There's a poszibility of contaminated fuel,.. Quote Link to comment Share on other sites More sharing options...
