As per the scan report IMA Battery Usable Capacity is 75%. That means the battery is in very good condition as per this report. Most probably the previous owner has replaced the hybrid battery since this battery is having the maximum usable capacity in terms of a IMA hybrid battery.
Was this scan report obtained from the agents? If you trust this report there doesn't seem to be any issues related to the hybrid battery. What's the manufacture year of this GP1?
When it comes to the condition of the car; a scan report alone is not sufficient to tell that. You will need to go on a test drive and see how it drives, check if the previous owner has maintained and serviced the car regularly (see records), condition of body panels to see is there are any bad accident repair jobs, suspension noises, tire condition and since this is GP1 be sure to check if this has the famous oil burn issue :)
So, if the above criteria are up to your satisfaction the car would be in good condition. Since, you are talking about a used car there would be some sort repairs that you will have to do eventually :)
even though the battery is 75% the voltage for all the cell be same. the above report says 6.30 and 6.40 when I checked they said the voltage should be the same according to staff***
Could be ... However when i took a report for my  2012 GP1 in 2018 it still had 75% which as you mentioned is the highest as it can get.
13 hours ago, zack.p said:
Is it this car in good condition
What's the YOM and Mileage?
