March 14, 20242 yr @Buccinatorย you had non smooth drive and unusual vibrations while driving ? How much did it cost you to replace ? I had the same warning lights while I drive, I couldn't take reverse since the vehicle was vibrating too much. In addition I could see Engine warning sign too Anyone had the same issue with Vezel 2014 ? ย
May 15, 20242 yr @nmx58ย Helloย I am facing the same problem same things you mentioned before can you tell me how much did it cost to fix the connection?ย
December 22, 20241 yr Honda Vezel 2014 Non Hybrid RPM below 500-600 car start but driving and moving, than car stsrt off. Plaseย
December 31, 20241 yr On 12/22/2024 at 11:52 AM, Md.Nazrul islam Liton said: Honda Vezel 2014 Non Hybrid RPM below 500-600 car start but driving and moving, than car stsrt off. Plaseย honda vezel idel stop wornt work, no idel stop sign on bashboard, battery helth is good, RPM 600-900 up -down.ย
January 24, 20251 yr On 8/16/2020 at 4:34 PM, iRage said: Well...this is rather sad and truly would be scary. Anything to do with the effectiveness of brakes is quite unnerving.ย I think I mentioned this before as well...does the car's Hybrid system work properly (does it run on the gasoline engine a lot more than it used to or compared to other Vezels) ? If memory serves me rightย (I read on some Japanese tech forums) the Honda VSA, CBTA,Hill Start assists go bonkers when the Hybrid system is not working properly and the engine is constantly running (the system apparently gets in to panic mode because it is not entirely certain the constant running engine will be fast to react). So this can be why your hill assist does not work...and since the Hybrid system uses braking to regenerate itself....it could be that your weak braking is messing up the full charging process. Iโm having the same issue right now! Literally all the dash lights comes on and once u reset, it runs for awhile. Again it comes back. I have no idea how to solve itย
