sira Posted April 1, 2020 Share Posted April 1, 2020 (edited) Dear Friends, During these times, just thinking to do an Engine tune-up or fuel system clean up for my GP1 by myself self .it is now 80K and never cleaned. well, I got a "WURTH" injector cleaning can with me and just to know how easy / Difficult is this task. As far as I know, accessing the injectors are really a hard job as it needs to remove intake manifold assembly and Throttle body one by one . Yes throttle body will not be touched and it will be done finally. (coz i do not have console) apart from this , is it risky? I have done This clean up for my earlier models - EK3, Swift(beetle). This is my plan - clean Injectors, Plugs, EGR (does it required to dismantle? ) and Finally throttle body Someone said to me to clean the fuel pump filter which is located under the gear lever? is it a must? Please advise your views on this and highly appreciated it Edited April 1, 2020 by sira Quote Link to comment Share on other sites More sharing options...
AVANTE Posted April 2, 2020 Share Posted April 2, 2020 Boring times nah? Some of us really do get tempted to do somethings in our rides Anyways 80k is a good point to do a tune up. I'd say just wait for all this to pass up and do it with a professional. Then you could even get the throttle body cleaned properly & TPS calibrated, which is vital. (Also, I faintly remember being told that using the cleaner while the engine is running and the throttle body is still in position can be a bad idea). The fuel pump filter is a must! Doing a tune up without cleaning that is like making Pol sambol without the Pol. Removing the intake manifold to reach the injectors? I don't think so. You mean that plastic cover that looks like an intake manifold? That's nothing. You would have to remove the TB and injector rail. Re-installing the injector rail can be tricky sometimes and also you are better off cleaning and checking the injectors with the tester/cleaner machine the shops have. The last thing you want is your car to be sitting at home, quarantined because it's throwing weird engine check lights and codes. Quote Link to comment Share on other sites More sharing options...
