Could you please give me an idea to my problem? There was an external metal piece of size around 5mmx3mmx2mm on top of 4th piston of my engine (5A-FE). Luckily it had only carved small areas (5mmx3mmx2mm) on piston crown and also head surface. I removed it. I was unable to remove the piston and check. But from top there were no cracks in the piston. With this metal piece engine ran around 20kms. Now after I removed I feel the engine is vibrating in high rpms than before. Also there is a very small sound coming from the engine. Could you please advice me to what can happen to the engine due to this metal piece? Has my crank shaft bent? Has my 4th piston connecting rod bent? I highly appreciate your kind reply.
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
Ted
Dear Fellows,
8 answers to this question
