July 20, 20206 yr Hi I have Toyota Corolla AEE90 which do not have any Power Steering Any One who have experience to convert it to Electric Power Assist Steering I think it is more easy than hydraulic power converter Please advice Thanks In advanced
July 20, 20206 yr Haven't done an EPS retrofit - did a HPS conversion but EPS should ideally involve changes to the column - bit of chopping involved
July 20, 20206 yr Author It is orsum , Some hard modification to be done . Electrical part is much easy . Any way thanks for the help
July 20, 20206 yr Anyone got experience with hydraulic-electric power steering swap? It the intermediate technology between fully mechanical and fully electrical power steering. You get to keep the same oil system, rack etc. Only difference that the oil pressure is generated by an electric pump activated at low speeds, instead of constant running mechanical pump. The only thing I like about my Peugeot 407, it's smooth like a hydraulic system but still quiet, efficient and easy to maintain.
July 20, 20206 yr 10 hours ago, dayanpad said: Hi I have Toyota Corolla AEE90 which do not have any Power Steering Any One who have experience to convert it to Electric Power Assist Steering I think it is more easy than hydraulic power converter At the end of the day..wouldn't it be easier to find the stock system and just swap it ? This is more adventurous and quite a educational experience..but simplicity wise ? Or is finding an old E90 with power steering more of a challenge ?
July 21, 20206 yr Author Yes you are correct If we have a video exactly swap the E90 car then well help full Unfortunately I did not find it I believe that alto 800 car electric power unit may be help Advice is needed
July 21, 20206 yr here is a thread on hybrid conversion, toyota MR2 pump on a BMW E46. https://www.e46fanatics.com/threads/electric-hydraulic-power-steering-conversion.1250691/ Advantage: no need to change the Rack, Hoses
