Dear All , Have a nice day
One of my friend have a Vitz 1300cc car Automatic
Mileage is 140,000 Model 2008
When car keep 5 minutes at start the water come out from the silencer
The emission testing report says Estimated test fuel cost Rs /Letter is 0.34 at Idle and 0.29 at 2500 RPM
Car is very good pickup condition
But
When oil limit indicator stick is removed the oil bubbles come out
So is this some issue with engine
If it is issue So what kind of solution to be done to recover
Still he doesn't know that the oil is burning since he brought it last week
Please see the attached emission testing report
Please advice
Please advice
Edited by dayanpad
Why did you removed it during engine running? Don't do it.
  • Confused 1
We used to this method to check the engine condition
What do you men , Is there any issue remove it while engine is running
Please advice the resewn to oil is  spraying  when oil dipstick is removed
Please advice
Edited by dayanpad
15 hours ago, dayanpad said:
But
Okay I'm curious: What does that test tell you?
  1. Check if you get blue smoke from the exhaust when the engine is hot. ( Indicates high engine wear )
  2. Check if you get blue smoke from the exhaust during a cold start ( Indicates your valve guide seals are bust )
A little bit of oil spraying out from the dipstick while the engine is running is fine. Since your emissions report is also good and the car seems to be pulling well, I wouldn't say this is a problem.
To figure out if your engine is burning oil,
  1. Measure your oil level then drive about 1000km and check oil level again. If it has reduced then you know there is a problem.
  2. Once your engine is at running temp check if you can smell burning oil from the exhaust.
Quote
Also you can't exactly tell engine condition via this method. This method would work if the engine is really worn out and had massive blow by. If you really want to know, run a compression test on all four cylinders. Please note that I am not an expert?. This is just from my personal experience.
  • Thanks 1
I believe that my method is not scientific way to check the engine condition , However most general people used to check it like that ,
I used EE90 Toyota Corolla ( E9 Series ). I used it over 9 years , I checked this method and I have never seen that any single oil dot come out from the dipstick hole, even at 2500RPM ( I am pretty sure )( This is my personal experience)
To come out oil from the dipstick hole , there must be a vacuum pressure inside the sump , As per the piston working method , it can't be built  any vacuum pressure for sump.  If there any vacuum pressure inside the sump , there must be compressor leakage  to the sump , Hence oil can be spreed from the dipstick hole ( I believe this is the way average people is thinking )
Anyway dear Kadsa09 your advice is very helpful me
Thanks again and again
Please advice
I agree with @kadsa98
I did it (removed dipstick while engine running) once for a very new engine (less than 15,000 km) and observed tiny oil bubbles. So, I never did it again.
