​ Welcome Forum Guest! 👋 ​
AC Water Dripping from Night till Morning
Hi Experts,
My car is dripping water from the AC drain pipe from the time I come home (at around 8 p.m) until morning-afternoon (1 p.m) the next day.
I usually use the AC for about 4-5 hours a day.
Is this normal?
Thank you for your responses!
- Z
Could be that your AC is building up a lot of ice inside....this can happen if there is a pressure issue within the system (so I have been told). This can happen because things like the AC/cabin filter is clogged up and builds up gooey moisture....or even gas being low. I know nothing about HVAC systems....did you have an AC tech look at it ?
17 hours ago, Zinger said:
Hi Experts,
Is this normal?
- Z
Ha Zinger,
Worth checking if the dripping tube clogged with some debris?? It was the case for one of my mate recently in SL.
Best to check with a reputed A/C tech and it could be what iRage indicated.
regards,
JC.
