Hi All,
If any one know best place to purchase recondition honda vezel 2015 ABS unit (T7BJ9), please mention the contact details. Please let me know that repairing ABS unit is a good idea or not.
Thanks All
Whether the ABS unit can be repaired (or should be repaired) or not depends on the actual problem.
Have you checked with Stafford about the cost of a new one ? You obviously can buy a reconditioned unit..but that is also a gamble as you do not know what the condition of the unit is (some shops do give a few months warranty). Also, if the ABS unit is known to have a certain failure rate, then you never know at what point the used part would go bad.
So...please do check the price of a new one and a used one and compare the prices and only go for a used unit if the new part is unreasonably expensive (eg...a bnew part costs 4 or 5 times as much as a used part...).
As for whether to find it...I don't know...maybe the Honda owners on the forums can recommed reputable Honda parts specialists. If not you will have to do some hunting around in Delkanda and PKW.
  • Thanks 1
