2 answers to this question
On 8/21/2021 at 9:36 AM, Rukshan Deva-Adithiya said:
Hi, I lost my braking power and the TRC light started blinking with the alarm , the brakes were down to almost floor level and most of the warning lights were on.
Anyone can help?
As Noddy mentioned it could be the ABS accuator issue which is quite common. New accuators do cost a bit and used ones are around. However, you never know how long a used unit would last, so its best to go for a new one or one that has been refurbished in Japan (which means you need to buy it direct from Japan as you cannot trust the sellers in SL). Better go for a new one.
There are garages out there who fit the brake unit from the previous generation model (XW20 series..your's is a XW30 series) The systems are different and these guys fit it by completely mucking up the car. DO NOT do that !!!! Fit the right part !
