3 answers to this question
On 1/24/2022 at 2:26 AM, Sonia Lutchman said:
Does anyone know what this message means?
It says the (drive) battery cooling parts needs maintenance at the dealer.
So probably your hybrid battery tempreture is higher than usual. The simplest reason this happens is when the air circulation vents to the batteries get clogged (sometimes iwth dirt, sometimes with oversized floot mats) and needs cleaning. When was the last time you serviced the hybrid system ? You can clean the vents by yourself, but following that you might want to get the system serviced.
  • Thanks 1
Best what you could do is use google translate on your phone.
It says something like drive battery take to service station
Edited by Gummybr
