Looks like I seem to have taken over the title to the only active member with Peugeots. Honourable mention @AVANTE. Hopefully did not miss anyone else.
Peugeot offers good value for money and are loaded with toys. but regular maintenance is required and sometimes can be pricey. Very nice to drive safe cars. Not for faint hearted as these do like to throw issues. Mostly electronic issues, which turn out to be easy cheap fixes. but time and expertise is required.
NOT A REPLACEMENT FOR A 121/ALLION OWNER LOOKING TO GET "PRESTIGE" ON A BUDGET. SORRY
Since I'm bored, I decided to make a comprehensive study on the French fry AKA Peugeot.
Covering Peugeots from the 90s to current models. Mainly talked about are 206,406,407,508,3008,5008 as these are common cars for us.
Let's start with the Negatives first.
Posting in table format for easy reference.
PRICES ARE IN LKR AND BASED ON SRI LANKAN RATES AT THE MOMENT. WILL BE CHEAPER OVERSEAS.
I will make edits or changes with time if required.
I do not take responsibility on anything and claim to be an expert. Compiled from experience and help from Peugeot Technicians.
Some of these negatives apply to all Euros and even some modern Japs.
Negatives
Fixes and avoidance guide
Average cost
1
Electronics are questionable
Biggest let down. Come to think of it, All euro cars have rubbish electronics. Will leave you stranded more than once if you don't rectify asap. had to learn the hard way. At least the wires don't melt like my Alfa 156.
tops at around 100k
2
Complex suspension
Good handling and comfy. But like all euros they are expensive and complex.
Ride smooth. Slow down for pot holes/bumps.
407 had some fancy suspension and was known to wear out faster.
150k to 500k
3
Interior dislikes hot climate
Get good quality tinted(50K) done.
Use a windscreen shade when parked.
Avoid parking under direct sunlight for extended periods.
Replacement parts are actually very cheap. Unlike bmw spares, that cost the sky and melt if you even stare too hard.
50k
parts are expensive depending on the location and accessibility
In Sri Lanka parts are often more costly and bit low in stock.
Malaysia & Dubai stock for cheap.
Ali Express.com has OEM parts for cheap with shipping to Sri Lanka.
5
Needs specialised technicians
Like all euro cars. Everyday bush mechanics do more harm than good.
Company is subpar in Sri Lanka. Prices can be a hit or miss from them.
6
Engines from BMW MINI (Prince THP) are troublesome
Fun and very rev happy. sounds good. can do anything from 4kmpl to 15kmpl depending on the driver.
Best avoided. If buying. Make sure engine has been overhauled with the corrected parts.
HP fuel pump/injectors are known to fail also.
Injectors-35k. HP pump-250k. Overhaul cost-400k plus
7
AL4 gearboxes are troublesome.
Solenoids are known to fail. Not too hard a fix. Expertise needed.
Regular preventive maintenance is key to no issues.
50k
8
Paint can be hit or miss
Paint can fade/bubble over time.
Rust is also sometimes found.
Garage usage is advisable.
Company rates are ok. But needs to be micromanaged
16k to 400k
9
Periodic timely maintenance is a must (not a negative, but Lankans think it is)
Maintenance must be done on time. Cannot leave behind for later.
Esp 5w30 Oil is expensive in Sri Lanka for unfathomable reason.
Older cars can use regular synthetic oil and full service cost is on par with japs.
Filters are cheap and plentiful. Oil can be bought cheaper overseas.
10k-175k for full service in Sri Lanka Includes gear/brake/coolant fluid change
10
3rd party spare are not common
Cheap non oem parts are hard to find and easily perishable. Advice not to use non oem parts.
11
1.2 pure tech engines issues
Powerful and fun. Sound good.
Will be worn out faster because turbo & small engine works harder than higher capacity engine. This is relevant to all small turbo engines from any manufacturer.
Will need overhaul by 200k.
ALSO SOME ENGINES HAD TO BE OVERHAULED AROUND 30K DUE TO DESIGN FAULT. DONE FREE AT AGENT UNDER WARRANTY. MAKE SURE THIS WAS DONE BEFORE PURCHASE.
500K UPWARDS
12
3008/5008 Power steering rack
Was changed free at agent under warranty. Was partly due to bad driving/roads. CHECK BEFORE PURCHASE
250k upwards
RUNNING REPAIRS AND SUCH.
Very similar in price to other brands.
THIS TABLE IS ACTUALLY FOR 1ST TIME PEUGEOT BUYERS. PRICES ARE NOT SCARY AS THEY SAY. WILL ALSO HELP 206,406,407 OWNERS NO DOUBT.
Intervals have been posted after getting recommendations from several experts who work on PEUGEOT. Intervals may vary and should use caution always.
May have missed some. This table is for Peugeots from the 90s onward.
Part/s
Price (LKR)
Interval (KMs or time)
Advisory
TIRES
20k to 75k
Depends on tire. Usually 45k kms.
Tires cost the same as other Japs & Euros.
Use softer tire because suspension can be damaged with hard tires.
Dunlops are a good balance between price and quality.
Brake pads
7k to 20k
Last long really.Usually every 40k kms.
Available from 3rd party junk to brembos.
My 508 cost 16k a pair in todays prices.oem. not bad at all.
406 and them still cost under 10k.
Depends on driving habits.
Brake discs
10k to 60k
Same as above
Unless a stone or something scratches the discs, they last long and don’t screech. Of-couse brakes depend on the driving habits.
Any Filter
2k to 5k
Every 10k for oil filter. Cabin/Fuel filter every 20k or as advised.
Easily found.
AUTOGear oil
25k-100k
Older pugs I’d say at least every 25k. Newer pugs say lifetime but I’d say every 40k -80k to be sure.
Overseas it’s 20K MILES for older pugs and 50-80K MILES for newer.
But in Lanka better change bit earlier because of harsh conditions.
Lifetime oil is bs.
Newer pugs need 4 Litres of gear oil that cost about 80k.
Engine oil (older pugs)
10k- 20k
For older non turbo cars. every 10k if synthetic or 5k for mineral oil.
Cost the same as an average car.
No any special recomendations.
Engine oil (newer pugs)
50k average
508,3008,5008 and other newer models. Every 10k. Please do this ritually or you will have problems.
Esp 5w 30 is recommended.
But please check with agent/ booklet to make sure.
Mobil 1 or Total is recommended.
AC GAS
10k to 75k
Re-gas as neccesary. or check every 2 years.
R-134A (or HFC-134a) for most cars before 2016. Cost peanuts to gas.
The post 2016 onwards it was mainly R-1234YF (or HFO-1234yf) gas. Now that’s expensive. About 50k usually.
Is there an alternative to the Maruti 800? A friend of mine is looking for an extremely cheap to run and fix car for around 1.5M. While I do advocate old Japanese cars in that budget - if his need is basic A-B motoring at the lowest possible cost - maintenance wise and with fuel - is there any other option that I am forgetting?
Does anyone know how exactly this is supposed to work? They haven’t really started brand new imports again right?
Pricing seems relatively fine in the grand scheme of things, given how 10/15 year old cars are still pretty expensive in our market
A guy advertises a mileage blocker on the quick site saying that his device blocks the vehicle mileage from changing on the odometer. Is it legal to advertise stuff like this?
Bought a 2007 (Reg 2011) Vitz SCP90 (Mileage 180K+) for the family (will be used by my father). Seems to be in good condition but had some new owner repairs/replaces done to have a free mind.
fiat fan
Negatives
Average cost
1
tops at around 100k
2
Complex suspension
150k to 500k
3
50k
5
6
7
50k
8
16k to 400k
9
10
11
500K UPWARDS
12
250k upwards
Part/s
Price (LKR)
Advisory
TIRES
20k to 75k
Brake pads
7k to 20k
Last long really. Usually every 40k kms.
Brake discs
10k to 60k
Same as above
Any Filter
2k to 5k
Easily found.
AUTOGear oil
25k-100k
Lifetime oil is bs.
10k- 20k
50k average
AC GAS
10k to 75k
Check under hood to confirm type.
This Is also the same as any brand.
Clutch
@AVANTE I need help on this
Brake fluid
5k
Every 2-3 years is what’s followed in Lanka. So far no horror stories.
If you use brakes a lot due to racing or traffic.
Better go case by case basis.
COOLANT
25k max
Every 5 years. Almost never changed in Lanka. Some might change even sooner.
Water is not ok.
Use a reputed brand.
STR sold in supermarkets is water with green dye. Ask me how I know.
SPARK PLUGS
2k to 6k each
Pug recommends 45K kms. Can attest to that.
Cleaning and checking won’t hurt I’d say.
Ignition Coils
10k upwards each
Check every 20k. Lankans change when busted only. Usually can run for 5 years.
Buy and keep from overseas as is very cheap there.
Battery
40k to 125k
Battery prices are crazy now. Used to be half this. I’d say with prices now, run it dry.
Don’t let that mfr die. Expensive af.
My 508 cost me 68k for a new brand.
Amazon is about 90k.
Shock absorbers.
15k to 45k
Inspection is the best identifier
Wide variety.
Can even be rebuilt which I don’t prefer. But not too bad really.
Axle oil seals
25k
leaks gear oil. common issue after about 10 years. easy fix
needs some disassembly to fix. so better to use qualified technician.
to be updated.
( WARMLY WELCOME TO ALL COMMENTS, SUGGESTIONS, CRITICISM ETC. 😊 )
Edited by fiat fanADDING MORE INFO EVERY TIME
8 answers to this question
