U don’t have to go anywhere else when we have a source here in AL....
Fuzzo (10% commi. Ok...) :D
Edited by ash
you mean fuzzo has the stuff??? Hey how come he never told me...
Tnx Ash. Dymn! I also want to replace my stock light set... but in tight budget these days... :(
Hmmm, how come my help full party is not alerted. Terbaite, drop me a mail i will give his contacts
sure thing :)
at this rate, the bugger will have to put on CFL bulbs
:P good one
Fuzzo, i had to mod my rear lights i bought you as popos stoped and said the lights are confusing as the signal light is also a red light and when you brake the signal wont appear. So i had to cut one brake light out and turn it into a signal light blinker from the circuit
sure thing :)
:P gud one
Fuzzo, I am curious, from where do you get your projector lamps,
if its from Malaysia would it be possible for you to get some down for a Proton wira front headlights, cos i drive a mirage and I think the lights are both the same for the wira and the mirage
even better if its meant for a proton coupe cos then the back lights are the same too
thanks,
The Don
Don, drop me an email with your cars details. i did remember seeing some stuff for protons. will check it out and let you know...
the brand of the lights are sonar...
The Car is a Mitsubishi Mirage Coupe 1993 model,
This is essentially what the proton Coupe is based on excep the front cell is different and the Proton coupe has a 4G93 engine vs mine having a 4G91 engine.
I asked out of curiosity mostly but would be interested in getting rear and head lights towards the end of the year when I finally get to come home for a holiday,
Regards,
The Don
machan fuzzo, These halo projectors for honda's, do they come with the proper xenon lights, i mean the type with the xenon gas.
no they don't come with xenons.... and it clearly says to not use the projectors with xenons...
on the other hand, i do know of a person who has done the xenon conversion with the projectors and they look pretty decent... and still working..
Bro Any luck with my lights??? you know the car...
  • 3 weeks later...
Fuzzo any updates, did u find any matching lights for my Mitsubishi (something which fits a proton coupe)
drop me a mail on [email protected] if u do, as I do not think the higher powers will tolerate this thread much further
Edited by The Don
any chance you can help me out too Fusso ? For a Mazda 323
hmmm :ninja:
I agree :ninja:
Why is not good to use xeons with projectr lights? Heat?
i believe they discourage xenon with projector housings because of the heat...but i have seen a local car running xenons with projectors and they are working fine still....car is a yellow turbo hatch
Edited by MADZ
fuzzo... i thought xenons put out less heat than conventional halos...
don't HID's also have xenon as the igniter gas?
